Evap
Old Apr 2, 2020 | 06:59 PM
Ansisk's Avatar
Ansisk
Default Evap
Hi folks,
i have the dreaded P0440, P0441, and P0446 codes. I’ve noticed a gasoline smell in the rear driver side wheel well for a few hundred miles and assumed it’s from a rusted filler neck. Haven’t diagnosed it yet, but I have not had any codes until yesterday. Gas cap is good. It’s taken a while for the EVAP test to run, but now that it has these codes shows up. Could a perforated filler neck cause these codes alone?
Also I should mention that I have a rough idle at 1500 RPM on a cold start. Idles smoothly below 1000 and runs very well after it warms up a bit.
Old Apr 2, 2020 | 10:21 PM
Mrv8q's Avatar
Mrv8q
Here is a post from some years back: https://www.clublexus.com/forums/es-...-canister.html
TL;DR I wound up replacing the entire charcoal canister. In my case, it cured the problem. Hope that helps,
BigFoot123
RX - 1st Gen (1999-2003)
16
Feb 10, 2024 10:47 AM
tommy329
May 23, 2016 04:54 AM
hzaidi26
IS - 1st Gen (2001-2005)
Nov 24, 2014 07:27 PM
iridebmx
Feb 23, 2013 12:10 PM
BoostedE21
Mar 13, 2010 10:13 PM
