Going into reverse, side mirrors face down?
Old Feb 8, 2020 | 11:19 AM
zacreth's Avatar
zacreth
Default Going into reverse, side mirrors face down?
So I just picked up a 2016 Es300h and I noticed that the passenger side mirror will go down when you go in reverse, but the driver side one one goes down a little which doesn't mean anything to me so I wonder is that normal or does both tilt down when you go into reverse?
Also I notice we have the notorious analog clock problem where it goes fast. Usually in 24hrs it's about an hour to an hour an half fast.
Thanks,
Z
Old Feb 8, 2020 | 11:50 AM
Bylan's Avatar
Bylan
Both mirrors should tilt down when shifted into reverse.
One thing to note is that you can adjust where these mirrors move to when you shift into reverse. From the owners manual:
Old Feb 8, 2020 | 12:51 PM
lesz's Avatar
lesz
As explained in the picture from the manual in the previous post, you have to set your desired mirror positions twice.
First you set up them to the positions where you want them to be when are driving forward. You do that by adjusting the mirror positions while the transmission is in Neutral.
Then, you adjust the positions of the mirror to where you want them to be when you are backing up. You do that by adjusting the mirror positions when the transmission is shifted to Reverse (and, of course, keep your foot firmly on the brake while doing so).
Once you have set your desired positions for both forward driving and backing up, those positions will be memorized by the car.
Old Feb 8, 2020 | 01:09 PM
zacreth's Avatar
zacreth
Awesome! Thanks for the direct link and the explanation. I'll have to try that soon when I hop in the car.
Thanks!
Old Feb 8, 2020 | 01:13 PM
mcomer's Avatar
mcomer
lesz is correct and to add one clarification, the "going forward" positions can be memorized with the 1/2/3/set function
but the "reversing" position will be for all drivers when in reverse. It is not part of the seat/wheel/mirror/HUD memory.
As noted, centering the mirror selector will disable the reversing position if you are backing up a driveway.
Old Feb 9, 2020 | 12:07 AM
OBLexus's Avatar
OBLexus
Thanks,
Z
The clock in my 2018 ES350 does not loose or gain any time, so what you are describing is a bit strange.
It is, however, for me impossible to get the digital clock and the analog clock to match perfectly since they are set separately.
kenforum
RX - 4th Gen (2016-2022)
19
Jun 12, 2023 06:05 AM
MKIV98TT
Jun 18, 2018 12:27 PM
lex831
Apr 21, 2016 11:51 PM
Davidgs350
Mar 19, 2013 03:56 AM
sidwin
GX - 1st Gen (2003-2009)
Sep 7, 2012 08:55 PM
