ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   Does your car's engine sound like this? (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/930960-does-your-cars-engine-sound-like-this.html)
Armo91 Nov 4, 2019 04:11 PM
I am starting to get worried about the noises the engine is making. Is it normal? If not, what do you assume the problem is. Thanks in advance
https://www.dropbox.com/s/xqs33n7a3alm2vm/20191103_231417.mp4?dl=0
https://www.dropbox.com/s/r6lkjmxf65e88jc/20191104_182616.mp4?dl=0
https://www.dropbox.com/s/r3tcm2r1jj1gk9z/20191104_183016.mp4?dl=0
2016 ES350 with 60,000 miles
zes Nov 5, 2019 09:35 PM
I have not found Toyota engines to be particularly quiet. Your engine sounds fine to me, other than a mild clicking that sounds like worn lifters. That would be a little premature for an engine with only 60K miles. You may want that checked out before the warranty runs out. Did it run out at 60K miles?
Dampfwalze Nov 9, 2019 06:35 PM
I have 63k miles and do not have that clicking, knocking sound - oil changed every 5k on the engine.
GeeEss350 Jan 20, 2021 03:56 PM
https://www.dropbox.com/s/xqs33n7a3a...31417.mp4?dl=0
https://www.dropbox.com/s/r6lkjmxf65...82616.mp4?dl=0
https://www.dropbox.com/s/r3tcm2r1jj...83016.mp4?dl=0
Did you ever fix the noise?
Armo91 Apr 5, 2021 09:31 AM
To tell you the truth it sounds like that specific noise went away by itself. Are you having similar noises?
This is what it sounds like as of today
https://linksharing.samsungcloud.com/qAkcfohzAXgP
GeeEss350 Apr 5, 2021 09:37 AM
I think my engine is generally noisy, people are very quick to just say its the direct injection but are not differentiating between the sounds.
I recently did a flush and used 5W30 oil that I recorded in another post, not much change. I will be putting in TGMO 0W20 and updating soon.
Mike728 Apr 5, 2021 10:41 AM
Except, the 6th gen does not have direct injection.
oreguyd Apr 5, 2021 11:08 AM
That's sounds nosier than mine, (2015) and I hear that dreaded lifter ticking noise from engines made a few decades ago. But, will that do any damage? Definitely use the correct weight of oil as well as full synthetic. That will not change the tapping sound, though. Someone will know if that is harmful over the long run. If I was buying your car and I knew what the engine "should" sound like, I probably would pass. See if it returns or gets worse. It may not be that serious or caused by something minor?
