Navigation Question
Old Mar 7, 2018 | 12:17 PM
benzmac's Avatar
benzmac
Default Navigation Question
The white street line has little red dots on it. Yesterday thst line was blue. Is there a setting I am missing?
Old Mar 7, 2018 | 01:12 PM
mcomer's Avatar
mcomer
You have found "Route Trace". Go into the Navigation Menu ("Show on Map" on older Lexi)
and open "Map Information". You will see Route Trace. It will likely show it is on by the yellow
light on the left. Select it and tap it off. The disclaimer will ask if you really intend to delete the
map markings...Yes.
We have found a couple uses for Route Trace. When leaving the car with a Valet Parker...turn
it on. When you return to the car you would like to see a short path around the restaurant. If you
see a streak of dots leading to the nearest Discount Liquor Store...they took your ride!
Another use we have is when visiting a National Park. Lovely places but easy to get turned around.
"Look honey, we have gone past that waterfall three times"
Old Mar 7, 2018 | 06:48 PM
benzmac's Avatar
benzmac
Got it. Thanks
Old Mar 8, 2018 | 11:36 AM
benzmac's Avatar
benzmac
Still did not remove the dots
Old Mar 8, 2018 | 11:37 AM
benzmac's Avatar
benzmac
Old Mar 9, 2018 | 11:56 AM
benzmac's Avatar
benzmac
Is there another setting that I aa missing?
Old Mar 9, 2018 | 12:19 PM
mcomer's Avatar
mcomer
Turn Route Trace back on and then turn it off. When the disclaimer asks if you want to delete the dots...Yes.
Old Mar 9, 2018 | 01:26 PM
benzmac's Avatar
benzmac
Will do. Thanks
Old Mar 9, 2018 | 04:57 PM
benzmac's Avatar
benzmac
Originally Posted by benzmac
Will do. Thanks
That did it.Thanks
johnnylt
Aug 15, 2018 04:45 AM
MSAGRO
Sep 20, 2017 03:43 PM
klwagoner
RX - 3rd Gen (2010-2015)
Jun 5, 2017 05:59 PM
TXGS
Aug 16, 2006 07:12 AM
