no A/C
Old May 23, 2003 | 10:16 PM
illson_2k's Avatar
illson_2k
Default no A/C
Also my A/C doesn't work eitherr it blows out hot air
Old May 23, 2003 | 10:28 PM
amf1932's Avatar
amf1932
I hate to tell you, but all the problems you're having with this car will cost you a bundle to get them fixed properly.
Alan
Old May 23, 2003 | 10:40 PM
illson_2k's Avatar
illson_2k
Default How much $$$$
what would you consider a bundle
Old May 23, 2003 | 11:00 PM
amf1932's Avatar
amf1932
Between your oil leak, brake, and electrical problems I would think that it'll cost you well over $1000 bucks to get these problems repaired properly!!
Alan
Old May 24, 2003 | 07:45 AM
Gekko's Avatar
Gekko
your AC probably needs the EXPANSION VALVE replaced. total cost is about $350.
Old May 24, 2003 | 09:22 AM
amf1932's Avatar
amf1932
How do you know his AC needs just an Expansion Valve? Isn't it possible that he lost his refrigerant due to a leak, or maybe his compressor is defective? I think it's impossible to tell what component is defective without putting it through a battery of tests!
Alan
Old May 24, 2003 | 07:55 PM
Gekko's Avatar
Gekko
because it is a KNOWN ISSUE with older ES300's. also, i'm a psychic.
Old May 25, 2003 | 12:07 PM
flipside909's Avatar
flipside909
Lexus Connoisseur
25 Year Member
Default Re: no A/C
Sounds like you need a refrigerant recharge...or perhaps your compressor has gone out.
Old Jun 5, 2003 | 07:19 AM
sincere's Avatar
sincere
Lightbulb
I had the exact same problem with my 1995 ES300. No A/C , blowing hot air. The dealership at first ran a diagnostic and didnt detect any problems. They added refrigerant and said the A/C was cooling. After I drove off, the A/C was still blowing hot air. This is when they looked at it closely and isolated it to the evaporator/ expansion valve which is located in the dash.
this appears to be a similar problem with the ES300
Old Jun 7, 2003 | 07:20 PM
lexusk8's Avatar
lexusk8
Does the LED light located on the A/C button blink occasionally when turned on? If so, that means you have a problem with the compressor of the A/C unit, and should have it fixed by the dealership or service shop. Although this is one solution to the problem, a simple A/C recharge can only last so long; this is the same result for most of the older SCs. Expansion valve repairs are pretty costly, so you should consider that as a last resort. Bring your car for a good A/C diagnosis, and keep us updated.
Old Jun 10, 2003 | 09:41 PM
beab951's Avatar
beab951
Mine had a compressor failure, which caused the expansion valve to clog. Remenber, the enpansion valve doesn't fail, it is a pin-hole device that allows the preasure to drop, causing the freon to cool (PV=nRT). It just get plugged and doesn't let the freon flow.
Old Jun 11, 2003 | 09:43 AM
illson_2k's Avatar
illson_2k
Question I got a quote of $278.78 to fix my A/C
Thanks guys for all your suggestions...sorry for the long response I've been busy working and doing other things. Yesterday I had taken my car to auto body repair shop (he works on a lot of things...he does this right behind his house), well I had taken my car to him and he said that it's gonna be $163.00 for the R-12, $48.00 for the service, $4.00 for the oil, and $48.00 to find the leak <<<<that was the estimate. He said that there is a leak somewhere possibly from when I had my wreck back in December. Tell me what you guys think. I think it's too expensive but what do I know.
-Kev
Old Jun 11, 2003 | 09:44 AM
illson_2k's Avatar
illson_2k
Question
The A/C button does blink when it's turned on
Old Jul 9, 2003 | 12:21 AM
illson_2k's Avatar
illson_2k
Lightbulb problem solved
thanks again for all your help.....I fixed the problem for some reason a while back my father had taken out the fuse that works with the A/C. So I popped it back in and now it's running fine execept it's extremely loud
drwillis
Jun 13, 2016 06:03 PM
gmanjeep
Jul 10, 2013 04:30 PM
DK Audio
Sep 19, 2010 01:41 PM
Ssergio86
Jun 26, 2010 06:11 PM
jacques
Maintenance
Jun 28, 2005 08:49 PM
