2ES Odometer (possibly again)
Old Aug 16, 2016 | 10:51 PM
GEO255's Avatar
GEO255
Default 2ES Odometer (possibly again)
Attachment 393541Attachment 393542Hi All! My 96 2ES is slowly crawling towards registration. I've replaced the caps in the ECU, replaced the blown bulbs around the place, replaced ALL the bulbs in the cluster with LEDS (except the Airbag Warning and Alternator Warning lights, because with LEDS they glow very slightly all the time with LEDS. Possibly because LEDS glow at a lower voltage than incandescent bulbs do. In any case, if there are any warning lights visible, it won't pass inspection. Putting incandescent bulbs back in these locations fixed that.)
My last hurdle is the odometer. I bought a replacement cluster (well, three replacement clusters, actually. But finally got a "good one") and plugged it in just to see that the odometer worked.
Replacement cluster showing 299319 km
As you can see, the mileage is 299319KM.
Here is my original cluster with the CMC (Combination Meter Computer) from the replacement cluster swapped into it.
My cluster with the replacement board fitted. It shows the donor's 299319 km. Grrrr
The mileage stayed the same. Reading the odometer reprogramming thread here (https://www.clublexus.com/forums/es-...ogramming.html) says the odometer value is stored in the speedo. I used my own speedo but the reading stayed the same.
Soooooooo, the mileage must be stored in the CMC.
The how-to above is for a 3ES, has anybody here changed the odo value for the 2ES? I looked all over the CMC for the chip mentioned in the how-to, but I can't find it or anything similar.
I'd really hate to register my car with 299000km, when the actual car has less than 120000. Not to mention the confustion if I do and subsequently fix it.
Thanks peeps.
Old Aug 17, 2016 | 08:38 PM
808mcv20l's Avatar
808mcv20l
may have been easier to have your original gauge cluster repaired by one of those Electronics shops that advertise on here.
I haven't seen any repair guides for gauge cluster mileage adjustment for the 2ES.
I wouldn't register the car with the incorrect mileage especially one that high, it really reduces the value of the car and makes for some really awkward conversations if and when you go to sell it.
Old Aug 17, 2016 | 09:55 PM
GEO255's Avatar
GEO255
You're right, I should have had my cluster repaired. I think I might still. I'll send them my faulty CMC and reinstall it when I get it back.
Too late for holding off the registration, I did it this morning. But I asked if they record the odo and they said they DO but customers can't get access to the historical data. They said it doesn't matter what mileage is supplied.
Cheers,
Geoff.
Old Aug 18, 2016 | 02:33 PM
mmatheny's Avatar
mmatheny
Until you go to sell it!
Kwik8276
Dec 14, 2013 10:57 AM
bigblack06
Nov 12, 2013 07:10 PM
lanthern22
GS - 1st Gen (1993-1997)
Jan 3, 2011 10:06 PM
joeazy187
Mar 2, 2010 02:02 PM
brianfung
37
Apr 2, 2007 09:41 AM
