Starting problems
Hi guys,
So I've been having a weird issue with my car during the last week. The car won't start, the battery is good and tested the alternator was good, also checked the starter was doing well.
I eventually got the car to work later on in the day. I came to realize that it depends on the way I am pushing the key in the cylinder to start it up. It's really weird. Sometimes I have to kind of lean on it down and turn the ignition for it to work, sometimes have to really push it in sometimes I have to pull it towards me, you get the idea. Anyways, this takes 3-4 times every time I am in the car.
At first when it started acting up I thought it was because of the cold, because it only did it in the mornings. Then proceeded to be every single time I get to start the car. I fear it will only go on to be worse until it doesn't start anymore.
^^All these tries were using the OEM key that has the unlock/lock panic functions.
I just tried the spare key, and it seemed to do better than the remote one. It doesn't need as much harassment to work.
If I just put the key in and try to start it, it will click once then make a constant sound kind of like a buzz.
Could this be a failing ignition switch problem?
Attachment 372200
That's about it. I just completed 2 weeks with this car. So I'm not sure what the previous owner did.
How much is it for the ignition switch? Is it a simple DIY?
And if someone can get the part number that'd be great.
But I have done it on Honda. I believe the part is around $200. I had to remove the dash to access the ignition switch....I think it took me 2 hours?
But now that I think about it, this car is almost 16 years old, with 255k on the odo, you know for sure this car has been driven a lot, and every time it was driven this ignition switch was there to help start the car.
It seems to be acting alright today, I just have to handle the key like a very smooth feather into the ignition then switch easily to ignite the car. I hope it just remains like this and I don't have to replace this part.
If I ever end up doing it, will be sure to post back. Thanks for the feedback guys.
Try making a new key, since you say the (lesser used) spare is doing better.
What are the symptoms of it not starting? When you say it makes a buzz, is that the starter ticking? Does the security light stop blinking when you insert the key?
