High Idle - Help
Old Mar 25, 2015 | 07:33 PM
Jmiller10's Avatar
Jmiller10
10th Gear
Default High Idle - Help
High idle (1400 RPM) in park at normal operating temp. Symptoms are: cold start idle 1000 - 1100 RPM. As the engine warms, idle increases slowly to 1400 RPM. In gear at a stop engine idles at 1000 RPM. No check engine light. Bought 98 ES300 a couple of months ago (161k miles) and have replaced valve cover gaskets, spark plugs, wires, ignitors, water pump, timing belt, cam and crank seals, high pressure power steering hose and power steering return hose. Also replaced (not sure what its called) EVAP control vacuum rail (sits on top of the engine, above the ignitors). Bought this part used off a 2000 ES300. Have cleaned the throttle body and did a quick clean of the IACV (did not remove it). Can't find any vacuum leaks. Car runs fine, idle does not fluctuate and it does start right up. Any ideas before I consider taking it to the stealership?
Old Mar 25, 2015 | 08:34 PM
ES300NZ's Avatar
ES300NZ
make sure the throttle cable is 'slack' or ... not tight.
check the timing, one tooth out 'might' cause this.
check the piping after the afm for cracks etc.
blow 'smoke, coloured air, powdered chalk + high pressure (30psi) air)' into the inlet system after the afm (requires airbox & afm to be removed and pipe sealed up) to see if any vaccum leaks show up.
Old Mar 26, 2015 | 10:21 AM
lostape45's Avatar
lostape45
Was the idle high before you did all the repairs? Or was it like this when you bought it?
Old Mar 26, 2015 | 09:34 PM
Jmiller10's Avatar
Jmiller10
10th Gear
Thanks ES300NZ. I'll check the things you mentioned and post what I find.
Old Mar 26, 2015 | 09:46 PM
Jmiller10's Avatar
Jmiller10
10th Gear
Lostape45 - honestly i don't recall as I was more focused on the oil and power steering leaks I didn't get a chance to drive it that much before the repairs. I want to say it didn't idle that high before. The engine and interior are so quiet, my other car is an Integra, so I may not have noticed until now.
Old Mar 26, 2015 | 10:37 PM
ES300NZ's Avatar
ES300NZ
Originally Posted by Jmiller10
.... I may not have noticed until now.
I think you would have noticed the massive sudden jolt from neutral to drive, or drive to reverse, but if two purple midgets danced past breathing fire and riding pigs, you may have been so distracted that you didn't notice. :P
Old Mar 27, 2015 | 10:32 AM
lostape45's Avatar
lostape45
Yeah when it idles that high, there's a huge jolt when shifting, I mean even if you have the brakes on. I'm wondering if your iacv is sticking, like the motor in it is worn out.
Old Mar 28, 2015 | 10:17 AM
Jmiller10's Avatar
Jmiller10
10th Gear
UPDATE - High Idle fixed - Removed the IACV from the throttle body and found that the sleeve/valve was stuck. Cleaned it out following the steps in the video posted in the "--Idle Air Control Valve diy?" post and now idles fine. Thanks for all the help on this one guys - love saving money!
Old Mar 28, 2015 | 04:21 PM
ES300NZ's Avatar
ES300NZ
thanks mint dude, good stuff.
Boblex
RX - 1st Gen (1999-2003)
Nov 29, 2016 08:20 PM
STREETGS
Oct 4, 2016 03:30 PM
kevinsc300
May 6, 2012 08:30 PM
mechanChic
Feb 23, 2009 02:47 PM
Lsquared
Jan 28, 2008 10:16 PM
