Gooden
Old Feb 23, 2013 | 06:17 PM
rtriplett3's Avatar
rtriplett3
Default Gooden
How often should one change transmission fluid? +
Old Feb 23, 2013 | 07:11 PM
PuReChaos's Avatar
PuReChaos
Every 50,000 miles would be the best.
Old Feb 24, 2013 | 01:01 AM
Hayk's Avatar
Hayk
I believe most manufacturers recommend 30k, but I could be wrong. Some people change it every other oil change.
Old Feb 24, 2013 | 06:27 AM
moonphase's Avatar
moonphase
Apparently I posted to the wrong thread!!!!
Old Feb 24, 2013 | 06:42 AM
hypervish's Avatar
hypervish
I see that you have a 2005 ES, I'd recommended changing the transmission fluid every 30k miles as MrBooby mentioned. Be sure to use Toyota Type-IV ATF, you will need 3.7 qt to do a drain and fill.
Old Feb 24, 2013 | 04:01 PM
Hayk's Avatar
Hayk
Originally Posted by moonphase
The differential fluid should also be changed when the transmission fluid is changed on model years earlier than 2001. Tools required are socket set, 10 mm hex allen socket, and hand operated fluid transfer pump. The fluid should be the same Dexron lll etc. as what you put in the transmission.
Just fyi, the transmission is connected with the differential, so opening the transmission drain plug will also drain the differential. If you really want to be thorough, there is an additional plug just for the diff on the side. It's a little harder to open though. There is no need for a 'hand operated fluid transfer pump'. The transmission/differential gets refilled through the dip stick.
Old Feb 24, 2013 | 04:02 PM
hypervish's Avatar
hypervish
The 2005 ES does not have a plug on the side for the diff, like the earlier 4 speed ES's.
Old Feb 24, 2013 | 10:04 PM
rtriplett3's Avatar
rtriplett3
Thanks a bunch, I would have never known. I will change oil soon and definitely change tranny fluid, above was mentioned Dextron III, and also Toyota IV ATF, are they similiar or the same?
Old Feb 25, 2013 | 03:36 AM
hypervish's Avatar
hypervish
They are different (T-IV has more friction modifiers), you MUST use Toyota Type IV ATF.
Old Feb 25, 2013 | 10:42 PM
Hayk's Avatar
Hayk
+1 Different fluids for different model years. Yours needs the T-IV, which can easily be found at any Lexus/Toyota dealer. Shouldn't be more than 6 bucks a quart.
20012003rx
Jul 7, 2014 08:51 PM
schmoozer
Jan 11, 2014 01:07 PM
clubsport
GX - 1st Gen (2003-2009)
Feb 28, 2012 12:51 PM
NEbiker10
Dec 6, 2010 04:01 PM
msdelexus
14
May 31, 2010 02:04 AM
