pumping gas problems...takes forever!!
Old Mar 7, 2011 | 09:43 AM
570sxpwns's Avatar
570sxpwns
Default pumping gas problems...takes forever!!
any normal car while pumping and the gas tank gets full the nozzle clicks and stops pumping, my 99 ES300 while pumping stops every 2-3 seconds nozzle clicks and if u force the nozzle gas will shoot back out...
anything info will help thanks..
Old Mar 7, 2011 | 10:07 AM
PFB's Avatar
PFB
That symptom normally points to a plugged vent, however a plugged vent should have triggered a check engine light, with an evap system code. So it's a bit puzzling.
Phil
Old Mar 7, 2011 | 10:14 AM
570sxpwns's Avatar
570sxpwns
yea no check engine lights, maybe its something mechanical and not electrical, maybe a clogged hose or valve....i just dont have a clue
Old Mar 7, 2011 | 10:23 AM
PFB's Avatar
PFB
A clogged hose or valve would have caused a CEL to trigger, that's why I said that it's puzzling.
Here is a link that may help you
http://www.toyotanation.com/forum/ar.../t-196695.html
Phil
Old Mar 7, 2011 | 05:42 PM
exxonham's Avatar
exxonham
Maybe try a different gas station? lol not sure if u go to same one but sound like the gas pump is messed up
Old Mar 8, 2011 | 12:38 AM
eyezack87's Avatar
eyezack87
Sometimes the pressure acts up against the thing. I found driving around a bit then releasing the pressure resets it. Stupid thing really
Old Mar 8, 2011 | 08:47 AM
lex2001's Avatar
lex2001
I had this happen on a Ford van. The vent was clogged or bent. Easy fix at the shop.
Old Mar 8, 2011 | 09:54 AM
01LEXPL's Avatar
01LEXPL
I'm inclined to agree. I had the exact same thing happen a month back. I didnt think much of it, filled up 10$ and drove somewhere else ad filled it up - it was fine.
Old Mar 9, 2011 | 10:37 AM
eyezack87's Avatar
eyezack87
It did freak me out a bit though. I had no gas to get home when it happened haha
gs350lex
Apr 13, 2019 07:38 AM
jasone36
Feb 5, 2010 06:30 AM
EScrow
Jun 26, 2009 10:32 PM
Antphilli
Aug 20, 2008 10:42 PM
lexluger71
Jun 10, 2007 10:23 AM
