wiring issues
Does anyone know of or have have a copy of the wiring diagrams for a 95 ES, I have the 93, and the 97, and unfortunately there are too many differences between the 93 and 95.... thanks I am trying to figure out if the combination meter (instrument panel ) from a 93 will work..... they have different part numbers but other than an additional indicator (headlights on ) everything else seems to be the same..... the ckts are a bit different electronically, but I believe functionally they are the same.. any help is appreciated..
capn
capn
Here you go, good luck. I would also quess that the sensors are probably close enough. The one thing that I would be concerned about is the tach. The 93 has a conventional distributor ignition. While the 95 is DIS ignition.
95combinationmeter.doc
BigDog1011
Feb 28, 2015 06:21 PM
