98 ES300 Headunit Question
Old Feb 26, 2010 | 02:03 PM
hoonami's Avatar
hoonami
Default 98 ES300 Headunit Question
I searched but haven't got clear answers yet. since my stock headunit blacked out, it's time for a new/aftermarket headunit. and found few that i liked and figured/found dash kits but not sure on harness. no i would like to use the stock amp and speakers, which harness do i need to get for me to keep these stock amp/speakers? and is there anything that i should know about before the installation? any tricks? any wires that needs special modification??
Old Feb 26, 2010 | 02:09 PM
hoonami's Avatar
hoonami
and how to i make sure to avoid that engine noise?
Old Feb 26, 2010 | 07:29 PM
HamBurglar's Avatar
HamBurglar
Not sure of the harness you will need for your year ES, check with Crutchfield.
I would throw out the factory amp and just power the speakers from your headunit it'll be louder and sound better (atleast on a 94 it did, probably the same for yours).
Years ago when I left the factory amp in I got that stupid noise when you accelerate it got louder, dumped the amp and it went away.
Good luck.
Old Feb 26, 2010 | 09:26 PM
01LEXPL's Avatar
01LEXPL
i was poking around on amazon.com today and they sell a few pieces you may need. check there.
Old Feb 26, 2010 | 09:36 PM
hoonami's Avatar
hoonami
thanks... any link??
Old Feb 26, 2010 | 10:22 PM
jami1's Avatar
jami1
I have the same question, I see alot of new head units that have built in GPS, and I am wondering if they fit in my 98 es. I see alot of them say Double Din, I am not sure if the 98 ES has double din.
Old Feb 26, 2010 | 10:40 PM
hoonami's Avatar
hoonami
you can buy any single and/or double din. you can easily buy single and/or double din dash kit from ebay, amazon, or crutchfield. and it will fit our model es300s with no problem
Old Feb 27, 2010 | 06:54 AM
97'ES's Avatar
97'ES
Is their an easy way to run the stock sub with the aftermarket deck and amp or do u have to use the stock amp? been wondering that...
I see most say they are 4 channel. Double din is the stock size but I'm going single due to cost.
Old Mar 8, 2010 | 07:43 PM
caleba1's Avatar
caleba1
the harness for most lexus es300's at least for mine come with av jacks (good because u can run it off ur old amp u just connect to the amp outs on the aftermarket head unit) (bad in my case cause i have a 10' cerwin vega sub that i cant run off the back of the head unit. so i stuck with just using a line converter on the back speakers still sounds good. i might later on get a splitter and run my cables up to the radio. as of now I am not.) if this answered ur question u can run ur same stock amp. the harness is made for it.
jankiwi
Nov 4, 2021 12:53 PM
singleton
Mar 28, 2012 06:27 PM
shahir18
Jan 29, 2007 06:45 PM
whatuusay1
Nov 12, 2004 03:47 PM
TerryTCL
May 14, 2004 08:35 AM
