hi-beam light bulbs exploding... es 330 2004
Old May 14, 2009 | 11:42 AM
Trainwreck's Avatar
Trainwreck
Default hi-beam light bulbs exploding... es 330 2004
I recently had my es 330 2004 sport design serviced. I had two hi-beam lights out(exploded). They were replaced and a week later the passenger side hi-beam exploded again. Any ideas would be helpful, thank-you.
Old May 14, 2009 | 12:14 PM
JSM1284's Avatar
JSM1284
Did you repalce them with stock bulbs? The usual cause of bulbs exploding is if you touch the glass with your bare hand.
Old May 14, 2009 | 12:47 PM
mmatheny's Avatar
mmatheny
True - skin oil will cause a burst. Use a rag to handle them. Yo can even use alcohol to clean them off first.
Old May 14, 2009 | 01:58 PM
03 ES's Avatar
03 ES
agreed.
i always use gloves when handling lightbulbs to avoid having an explosion.
Old May 15, 2009 | 09:06 PM
Trainwreck's Avatar
Trainwreck
Thank guy's, but the bulbs were replaced by a Toyota dealership. Past work on my ES 330 has been top notch. I forgot to mention 4 days before my 2nd set of bulbs exploded, my car wouldn't start. Battery was boosted and my car started instantly. Checked battery(indicator was blue) full charge. Checked for loose connections.. none. Could a voltage regulator be bad? What else might fit into this scenerio?
Old May 16, 2009 | 10:41 AM
96Schwarz's Avatar
96Schwarz
Do you have moisture in the headlight housing? If the water hits the hot bulb it will explode. Check for water leaks and repair accordingly.
Old May 16, 2009 | 05:28 PM
mmatheny's Avatar
mmatheny
The "voltage regulator" is in the alternator. At an idle,you should be getting about 12.5-13 volts at the battery (assuming a fully charged battery). Rev it up, it shouldn't go up.
njb2010
RX - 1st Gen (1999-2003)
Jun 21, 2010 05:53 PM
pinoyballa
Nov 29, 2007 08:54 PM
vboy418
Oct 5, 2006 04:36 PM
steviej
Mar 30, 2005 06:35 PM
