Headlight Headache
Old Jan 1, 2009 | 08:06 PM
Sash's Avatar
Sash
Default Headlight Headache
So where do I begin . . For the past month my passenger side headlight has been turning off by itself , either while driving or just not powering on when starting up the car. After a few flicks of the headlight off/on switch the headlight magically starts up. The past week, this started to happen more often . . I'd be standing at a traffic light and it would turn off atleast 5 times and require me to turn my headlights off/on a few times before it turns on.
I decided to try and find the problem (bad idea) , I checked the ballast, bulb, wiring, everything seemed fined especially being that I just put in new ballasts / bulbs 3 months back. After unplugging and replugging everything my passenger side headlight won't turn on at all. It starts to flicker non stop, almost like police sirens. At this point I've completely unplugged all the wiring and have no idea what to do. Everything was plugged in when it flickered, the drivers side light works perfect, the ballast and wiring for the light seems fine. What am I missing?
Does anyone have any recommendations?
Old Jan 1, 2009 | 10:25 PM
eyezack87's Avatar
eyezack87
If you have a relay connected to the battery, the fuse on that thing might be dead. Same thing happened to my friends Avalon of the same year. The contacts were corroded due to water/whatever so we replaced it and the problem was fixed.
Hope this helps
Old Jan 3, 2009 | 08:55 AM
Lexucan's Avatar
Lexucan
Lexucanafer
Yep, definitely sounds like a bad (loose or corroded) contact somewhere in your HID wiring harness.
Old Jan 3, 2009 | 03:49 PM
Megafast13's Avatar
Megafast13
yeah, its just a wiring problem with the HID kit..
Check a fuse in the harness.
Old Jan 3, 2009 | 07:02 PM
trukn1's Avatar
trukn1
NELOC Mod
As others have said,, def a wiring problem. Even though your ballast are new, you may have just gotten a bad one. Same thing happened to my bro with his Tahoe. In his case the ballast was drawing an excessive amount of power, thus over powering the ballast itself. Check the wiring, and you may need to contact a shop in order to have a power reducer installed.
Old Jan 5, 2009 | 11:21 PM
Lazy's Avatar
Lazy
Mines did the same thing. I called it unique and it was my transformer! haha..
Old Jan 30, 2009 | 05:29 PM
admbear's Avatar
admbear
04Es330 I bought last Nov. has a problem very much like those described by Sash. I replaced passenger running light bulb with no luck. Circuit from swich is live and solid so currently suspect headlight module/ballast. Will check fuses as recommended. Dealer wants $425 for the module. I believe in everyone making a living but not by mugging. Anyone know of an alternative source for the headlight module? The driver's side works perfectly. This new guy glad to find you folks after a long day of searching the Net.
Old Feb 2, 2009 | 09:22 PM
Carnut's Avatar
Carnut
Anybody ever tried to buy/replace the passenger side turn signal assembly on a 2000 ES300 ? Mine is busted (cracked badly) and needs replacing. From looking under the hood, it looks like a chore, unless you get some good advice.........anybody that can help I sure would appreciate it.............Carnut1
JDMV8
IS F (2008-2014)
May 25, 2017 06:36 AM
zapola6
Jan 5, 2015 04:51 PM
ncgirl05
Dec 23, 2011 02:17 PM
lakersfan0
Jun 10, 2009 03:33 AM
