Passengers Side Mirror :(
Old Dec 8, 2007 | 10:53 AM
Saurabh's Avatar
Saurabh
Default Passengers Side Mirror :(
I am new to these forums, i have joined because recently i smashed my passengers side mirror when i was backing out of the garage. I am trying to find a replacement for the car. My model is Es-300 2002. I have no idea how to go about fixing the mirror, Im not sure if insurence will cover it and were should i buy the part and what parts will fit. My car is factory silver and i found a mirror, but im not sure if it will fit because the seller does not specify what make is it. Can someone help me out please. I can offer as much information about the car if needed.
Link to The Ebay product.
Thanks Saurabh
Old Dec 8, 2007 | 12:41 PM
Choas's Avatar
Choas
CL Folding 10,000
What a sad way to be welcomed to CL. On that mirror I don't see a year so it may not fit.
Old Dec 8, 2007 | 02:16 PM
Saurabh's Avatar
Saurabh
Well i talked to the seller, and he said that if the product does not fit, he will refund my money if i send it back to him. I called lexus and they said the mirror would cost 575 dollars, so i ordered the mirror from this guy for 100 dollars plus 25 dollars priority shipping, so when it comes in ill let you guys know. But how would i install this mirror? Thanks.
Old Dec 8, 2007 | 06:42 PM
TORTOISE's Avatar
TORTOISE
Did the mirror break clean off?
Old Dec 10, 2007 | 03:00 PM
Saurabh's Avatar
Saurabh
It didn't brake clean off, just a huge crack on the glass, plastic is broken ext. The mount is fine. But i bought the side view mirror for 125 dollars including shipping which was 25 dollars but i did order the part on Saterday and it arrived Monday. So my next problem is how to put the mirror on the car? anyone have any tutorials or can give me a guide?
Old Dec 10, 2007 | 03:15 PM
JSM1284's Avatar
JSM1284
That mirror will NOT fit. That is for the previous Generation ES300.
I believe so
Old Dec 10, 2007 | 03:20 PM
Saurabh's Avatar
Saurabh
i matched it will the car and it seems the same, how can i tell for sure?
Old Dec 10, 2007 | 03:21 PM
Saurabh's Avatar
Saurabh
Before i purchased the part, the seller told me he would give my money back if the part did not fit. how can make sure that it will or will not work? I have the part with me now btw.
Old Dec 10, 2007 | 03:23 PM
JSM1284's Avatar
JSM1284
Hmm, it looks like the older style in the pic. Whats the part number on it? Do you have memory seats/mirrors?
The little triangle piece behind the mirror on the inside of the door, Get your fingers behind it and give it a quick yank. Once that is removed, use a 10mm socket and remove the 3 bolts that hold the mirror in place, unplug mirror and replace with the new one
Old Dec 10, 2007 | 03:24 PM
Saurabh's Avatar
Saurabh
Thanks for your quick reply, give me a sec, were do i find it?
Old Dec 10, 2007 | 03:26 PM
Saurabh's Avatar
Saurabh
Toyota TR9604 i think
JSM1284's Avatar
JSM1284
The part Number should be either: 87910-33570 or 87910-33560
Old Dec 10, 2007 | 03:27 PM
Saurabh's Avatar
Saurabh
were do i find the part number?
Old Dec 10, 2007 | 03:28 PM
JSM1284's Avatar
JSM1284
Could be on the bottom of the assembly, or on the foam part that mates against the door, maybe under that.
Old Dec 10, 2007 | 03:29 PM
Saurabh's Avatar
Saurabh
Lhd-r 564022?
