Knock Sensor....!!!!!!
Old Nov 15, 2007 | 02:57 PM
Lexus4You's Avatar
Lexus4You
Default Knock Sensor....!!!!!!
is this the knock sensor???
wish i had a better picture but thats when i swapped my old engine... i really hate to have take all of that apart for a frekin sensor... but as i am told i better do it and if i dont i might blow up the engine.... not good... since i just replaced the damn thing..... any suggestions are greatly welcome....
Old Nov 15, 2007 | 03:01 PM
JSM1284's Avatar
JSM1284
One Knock Sensor is mounted on each side of the engine block.
Old Nov 15, 2007 | 03:35 PM
Lexus4You's Avatar
Lexus4You
even in a 93?... and also how do i know which is bad???.. im kinda on a tight budget as a highschooler..... u know... $250 is not something i can just throw around... especially for 2 little sensors....
Old Nov 15, 2007 | 03:37 PM
JSM1284's Avatar
JSM1284
What codes did you have?
If it was 55. That is the bank 1 sensor. Bank 1 is the side closest to the firewall.
Old Nov 15, 2007 | 04:08 PM
92ES5sp's Avatar
92ES5sp
Smile
Nice reply You might as well replace both sensors while you have the intake off anyway instead of having to do it twice.
Old Nov 15, 2007 | 05:26 PM
Lexus4You's Avatar
Lexus4You
does anyone know if there might be a problem with the jdm aspect of my engine... like maybe different knock sensor?... i really just hate to take it all apart and replace 2 small sensors for like 250 bucks... this really sucks.........maybe if i take out the fuse and "reset" it???... any clues on which fuse???? worth a try!
Old Nov 15, 2007 | 06:28 PM
JSM1284's Avatar
JSM1284
There is obviously a problem with the sensor, wiring, or ecu. You need to properly diagnose it by using the above steps to find out the problem.
Old Nov 23, 2007 | 08:58 AM
yr0169tw's Avatar
yr0169tw
If it were knock sensor porblem, reset is useless. I reset it several times but it still went on. After ignored the light for a long time, finally I replace the sensors, no more check engine light goes on and my 93 Es runs better than before. It's cheap in Taiwan, I just spent 170 for both sensors, labor included.
clubmark
Jul 27, 2015 10:18 PM
ADENNARD
May 21, 2013 06:27 AM
imAC
Apr 17, 2013 07:19 PM
vntperform
Aug 5, 2010 01:02 AM
Mike ES
May 13, 2009 11:36 AM
