Knock sensor location
Old Sep 19, 2005 | 03:26 PM
larryr's Avatar
larryr
Default Knock sensor location
Help!
I have a code 52 on a 92 lexus es 300. I read on the board that the knock sensors were under the intake, however after removing the intake they are not there. I know this is dumb but I cant see them anywhere there or on the side of the block. The 94 camry info also shows them under the intake.
What am I missing?
TIA'
Larry
Old Sep 19, 2005 | 04:06 PM
Pheonix's Avatar
Pheonix
Cool
Upper Intake Air Chamber
Intake Manifold
Tada!
See the two wires in the middle of the screen? One screws into each bank.
95% of the time the wiring is damaged. Knock sensors are a piezeo on a stick. Not really much for them to go bad.
Old Sep 19, 2005 | 04:32 PM
larryr's Avatar
larryr
Smile Got it!
Thanks a lot . Sounds like maybe just replace the wires and I will be ok.
Old Sep 20, 2005 | 12:30 AM
1993ES300x's Avatar
1993ES300x
Pheonix.. looks like you're rebuilding the whole engine. or are you just replacing the HeadGasket??.. how long did it took you??
Old Sep 20, 2005 | 08:49 AM
Pheonix's Avatar
Pheonix
Cool
Pictures from replacing the head gaskets, porting & polishing the heads/exhaust manifold/intake manifold/UIAC, deleting EGR, modding ACIS, installing the SMT-6, intake manifold spacer. God knows what else, I can't remember. Last September / October. Took a couple of weeks to do everything, but parts failure after parts failure kept it from running much through January.
Two timing belts, screwed cam timing directions,dieing fuel pump in January (I think). It sucked *** took forever. It was soooo worth it tho LoL!
Old Sep 24, 2005 | 07:32 PM
larryr's Avatar
larryr
Default Update
Replaced the wiring, which was in bad shape, but still have a code 52. Trying to determine which sensor is identified with a code 52. any one here know?
Tia,
Larry
Old Sep 24, 2005 | 07:43 PM
Pheonix's Avatar
Pheonix
Cool
Left bank, even bank, front bank.
richtbee
Nov 26, 2024 05:25 PM
Marinecorp
Performance
Jan 19, 2014 11:59 PM
babybucko
Maintenance
Jun 27, 2010 02:56 PM
Faymester
IS - 1st Gen (2001-2005)
Nov 24, 2006 05:28 PM
texaslexas
May 23, 2006 02:36 PM
