PCV problem...
hope someone can help me out, AGAIN...
i change my PCV valve since it was soo easy.. went to Auto zone and bought it.. asked the guy if he can locate it for me. he even help me take it out .. but it was so tight he pull it out wiht the top part of the PCV Garment.. he jsut went inside and got another garment and just place it on top of it.. i can see that its not fully fitted. thinking there's still part of the old garment still stuck in there.. my car started shaking two days after that happend.and the shaking comes and go's .. the more i push the gas. the more it shake. .. please . help me..
drive to toyota or lexus and get an OEM valve, itll cost you like maybe 3 dollars. you can prolly walk in there and have them replace the valve with an oem one for like 20 bucks. the reason its shaking is because there is air escaping somewhere there. if thats all you want the dealer to do, tell them all you want them to do is the pcv, if ya want them to do both the grommit and the pcv, call a day ahead of time and have them order a grommit for you, though those things dont fall apart to regularly, so they will prolly have to order em. when it comes to performance parts, ya go to a racing store like summit racing or somethin, when it comes to replacement parts, go OEM always.
I got a rubber replacement at Kragen's, not sure if you have them where you are.
You shouldnt have to go to the dealer. When I changed my PCV, the grommet broke apart and part of it fell inside, I got that out , got a new rubber grommet and all is well now. If your original is hard plastic, the new rubber one should be much easier to install .
It cost around $3 for the grommet.
Originally Posted by 1993ES300x
how did you get the part of the gromit out?? or did you leave it in there??..while changing my pvc, i think part of the garmit fell inside and i left it there , since it's rubber.. should it melt and come out with the oil when i do a oil change?? right now. it seems like my ES takes more gas and slow on boost..
I used a short thin common screwdriver to feel for the broken piece.
I got it positioned to a spot where I could get my needle nose pliers in there.
Then I SURGICALLY
removed it. I guess it wasnt that dramatic.Couple of other techniques that would work in hindsight might be:
Vacuum cleaner with very thin nozzle.
Tweezers might work if its long enough.
Superczar
Aug 19, 2009 09:02 AM
