spring or shock?
Old Oct 7, 2004 | 10:51 AM
slstsang's Avatar
slstsang
Default spring or shock?
I have a 92 es300, sometimes the front end will have trouble going over speedbumps, the bottom might hit it and make loud noise. i tried going to each corner of my car and push it down hard and test the shocks, it doesn't bounce up and down.... so could it be springs warning out? if so i can bought stock brings from someone else .... will it be a bad idea? how much would it cost to have someone change them? any estimate?
i also am looking for some leather shift *****, something to replace the stock wanrout ones, anyone have good suggestions? after market ones that doesn't look bad? any sugesttion is appreciated.
Old Oct 7, 2004 | 10:00 PM
flipside909's Avatar
flipside909
Lexus Connoisseur
25 Year Member
Default Re: spring or shock?
The ES does not have shocks, they are struts. Sounds like you have worn strut mounts and worn out struts itself. Springs don't wear out. I like the TRD Japan shift ***** for Toyota models. www.carsontuned.com has plenty to choose from.
Old Oct 8, 2004 | 03:46 AM
Lexus007's Avatar
Lexus007
I found this on that site for the es300 -97-01 model. How are you gonna fit that shifter on? Has anyone done it before?
Old Oct 8, 2004 | 04:25 AM
slstsang's Avatar
slstsang
Default Re: Re: spring or shock?
Originally posted by flipside909
[B]Sounds like you have worn strut mounts and worn out struts itself. Springs don't wear out. /B]
how much are the strut mounts? are there after market ones like the struts? how much would it cost to replace those just labor alone?
why is it not springs? someone said if struts wear out they'll bounce.... anyone got any suggestion?
Old Oct 8, 2004 | 04:29 AM
slstsang's Avatar
slstsang
agree, it is automatic and there's also overdrive button, besides levoc ones, are there any leather ones out there that looks good and also have overdrive button on it?
Old Oct 8, 2004 | 11:18 AM
flipside909
Lexus Connoisseur
25 Year Member
Default Re: Re: Re: spring or shock?
Strutmounts are about $80/piece at the Toyota/Lexus parts counter. Labor for that is about 2 hours. Labor alone should be about $75/hr avg depending on where you live. Springs don't wear out. If they wear out they will sag, but OEM springs never fail unless involved in a hard collision. Struts are the most common thing to replace on any vehicle..especially with high mileage. Struts eventually wear out and leak fluid, which causes the ride to get bouncy. No fluid to absorb = riding on springs and no shock absorbing action.
Old Oct 8, 2004 | 11:20 AM
flipside909
Lexus Connoisseur
25 Year Member
Unfortunately, the only option would have in terms of shift **** would be through Levoc. The leather/wood ones levoc has unfortunately causes the **** to sit high, almost like a UPS truck shifter. Unless you cut the shaft (which i wouldn't recommend), that would be your only option unless you rewire the o/d button to a remote location.
A.C Milan
Suspension and Brakes
Jan 9, 2012 10:46 PM
Kenny77536
May 27, 2009 12:28 PM
_DAG_
Apr 25, 2004 08:20 AM
Rro
Jun 29, 2001 09:17 PM
cyclemax
21
Apr 18, 2001 01:19 PM
