Coolant Level Low
Old Feb 18, 2026 | 07:50 AM
June1978's Avatar
June1978
Default Coolant Level Low
2007 ES350
Popped the hood to put in some washer fluid and noticed the coolant level is near the "L" line. Everything is working properly and I didn't notice leaks.
I was going to top it off but wanted to know if it's ok to use Zerex instead of the OEM Toyota coolant. I was also thinking about doing a complete flush when I take it in for the next oil change next month. I know my water pump was changed about 2 years ago so I'm not sure if they flushed it then or just did a top off since coolant poured out during the install.
Old Feb 19, 2026 | 01:44 PM
ESh's Avatar
ESh
You can use destiled water.
Old Feb 19, 2026 | 02:19 PM
Clutchless's Avatar
Clutchless
If your water pump was replaced 2 years ago then they replaced most of your coolant at that time. They will not save and reuse old coolant on a car that old.
Do not use Zerex. It is not compatible and will clog up your system due to chemistry not being compatible and the cost to flush it out will make you unhappy.
Distilled water is fine to top up that container. You need OEM fluid or Zerex Asian Vehicles, or Prestone Asian Vehicle coolant or the NAPA version.
Old Feb 19, 2026 | 02:26 PM
chuyrobles's Avatar
chuyrobles
I third, distilled water. If you know what was used when the water pump was replaced, use that or distilled water and nothing else. You next want to know why the coolant level is low. It could simply be that air bubbles have worked their way out from the last coolant change. Top it off and keep an eye on the level.
LexusRM
NX - 2nd Gen (2022-current)
12
Dec 10, 2024 02:21 PM
Marc780
Jun 4, 2023 06:36 PM
vbb
IS F (2008-2014)
Mar 23, 2014 10:47 AM
IntensaLex
IS - 1st Gen (2001-2005)
Sep 9, 2012 12:17 AM
shikbas
Jan 11, 2008 05:18 PM
