TPMS flashes briefly while driving then stops flashing
Old Feb 28, 2023 | 08:51 AM
EKL928's Avatar
EKL928
1st Gear
Default TPMS flashes briefly while driving then stops flashing
I bought this 2007 ES350 from a relative so I don’t know if the problem existed before or not. Also, it has been crashed when I bought it. The car bodywork is repaired and a bent wheel was replaced. All 5 wheel TPMS sensors were replaced (bought them from eBay for about $15 each, claim they are OEM) and I used an Autel scanner to read the sensor IDs and a VCi wire and my laptop to program the new sensor IDs into the ECU.
Now every time I drive the car, the TPMS dash light will flash about 7-15 times and stop. It does it just once or twice on a 30 mile drive. Every drive, it will flash after about 5-20 minutes of driving.
It never stays on solid. It just flashes 7-15 times and then goes dark.
I thought it was a defective sensor (normally works but stops working when driving). I replaced 2 of the 5 new sensors with OEM sensors. Still flashes briefly when driving just once or twice in 30 miles of driving.
Test: I deflated each tire to 20 psi and checked that the TPMS light does come on solid as soon as I start the engine. Inflated the low tire and TPMs light went out. Did this for all 5 tires. So all sensors are working and the system is reading.
Can it be the TPMS receiver? Or should I replace the remaining 3 tire sensors?
Should I pay the dealer to check the car or the ECU programming? Is there a clever way to figure out which sensor is causing the flashing?
Maybe I should remove the spare and leave it at home and drive the car to see that happens? Then I should install the spare on each corner of the car at a time and drive it to see what happens? What happens if you drive a 5-sensor system car without the spare tire in the trunk? Does it flash or go solid or do nothing?
Last edited by EKL928; Feb 28, 2023 at 08:53 AM. Reason: Added part about deflating each tire and checking that the TPMS light does come on solid as soon as I start the engiine
Old Feb 28, 2023 | 11:37 AM
nevernu's Avatar
nevernu
a small piece of black electrical tape placed over the light works for me (with summer tires, and winter tires I cant be bothered to play w this erratic system)
Old Feb 28, 2023 | 06:45 PM
TCoolest2's Avatar
TCoolest2
Did you try the Tire Pressure Reset Switch
https://www.lexusofcherryhill.com/se...ressure-light/
Old Mar 1, 2023 | 10:47 PM
lexo98's Avatar
lexo98
There are other threads here with the same issue until the sensors were replaced
rivec33
Sep 13, 2021 03:05 PM
Grateful1
May 31, 2021 02:41 PM
SpruceRain
Jan 18, 2020 08:27 AM
Ears
Nov 20, 2016 06:36 AM
dganapol
Sep 16, 2015 10:10 AM
