Headlight assembly help
Old Jan 22, 2023 | 03:51 PM
whatbraden's Avatar
whatbraden
1st Gear
Default Headlight assembly help
Hello, I was changing the low beams on my lexus. After i unplugged the light there was a metal clip i was suppose to squeeze off. Instead i unscrewed the metal clip from the assembly and the outer bulb shell fell back into the headlight assembly. My question is am i ****ed? Or can i get this bulb out, i messed with it a little and couldnt get it. Any opinions??
Old Jan 22, 2023 | 08:58 PM
Arsenii's Avatar
Arsenii
Hello,
A picture of the damage would be helpful.
Not sure how ... screwed you are, but in any case, you will have to take the light off and carefully try to position the reflector back with the light upside down, that will require a ton of patience I assume, so make sure to have a good night's sleep before doing it.
Hope this helps and best of luck!
