ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   Which Plug is cylinder 6? (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/975923-which-plug-is-cylinder-6-a.html)
TriniLex Nov 6, 2021 06:28 PM
I have a misfire in Cylinder 6. I plan on changing the spark plug and the Spark plug coil.
Can someone clarify which cylinder is cylinder 6 when looking at the engine from the front?
thanks
Arsenii Nov 6, 2021 06:30 PM
Hello,
Below is a Cylinder Identification schematic. Before committing to a new coil, try swapping Coils 4 and 6 around to see if the misfire would switch to #4, if so, then yeah, you need a new coil.
https://cimg6.ibsrv.net/gimg/www.clu...addb2c2aec.jpg
Hope this helps and best of luck!
TriniLex Nov 7, 2021 07:31 AM
Thank you for the diagram.
Turned out squirrels ate my fuel injector wires!
