ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   Cleaning MAF sensor (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/937326-cleaning-maf-sensor.html)
BFranklin Feb 2, 2020 04:38 PM
Cleaning MAF sensor
Hi,
Wanted to know if its safe to use crc maf cleaner on my 2003 es300. I discovered after i bought the cleaner that says on the back its not for use on most lexus vehicles that have karman vortex maf sensors . Is my car one of the exceptions? W
goose300 Feb 2, 2020 06:19 PM
I have used the crc sensorkleen cleaner to clean the MAF sensor on my 01 ES with no issues
Richardsr Feb 3, 2020 09:20 PM
When working on anything electrical on a Lexus, it is well advised to remove the Negative pole of your battery until you are complete. Computer operated cars, Lexus most certainly, are finicky and will generate codes and problems to prove it. Do your Lexus a huge favor and one day replace your MAF with an OEM Denso. Your cars ECU knows your MAF is aftermarket and will attempt to employ it but often with less than expected results, hence I always recommend Genuine OEM for electrical components.
While you’re cleaning your MAF, clean the connectors to it (let them dry thoroughly) and clean your Throttle Body while you’re in there. Not hard to do.
Lexus Part No.: 22204-22010
METER SUB-ASSY, INTAKE AIR FLOW
https://www.lexuspartsnow.com/resour...EA86AE9FF63CF6 Part Description Meter Sub-Assy, Intake Air Flow Manufacturer Lexus. This genuine Lexus part is guaranteed by Lexus's factory warranty.
Good luck with the Karman Vortex.
netlander Jul 18, 2020 06:22 PM
Hello,
Did u clean your MAF with "CRC 05110 Mass Air Flow Sensor Cleaner" ?? Did it go well, ie engine starts? Any improvements in performance?
artbuc Jul 19, 2020 03:24 AM
Originally Posted by BFranklin (Post 10723956)
Hi,
You don’t have a karman vortex sensor. You have a hot wire sensor CRC MAF cleaner is fine. Make sure you clean the hot wires. Many clean the IAT sensor incorrectly thinking it is the MAF sensor.
artbuc Jul 19, 2020 03:26 AM
OP didn’t say he had karman vortex...he was just quoting label.
