Whats your favorite or most ridiculous mod done to your ES? I have a lightbar on mine
10th Gear
I'm curious to see some of your mods on your lexus'. My most ridiculous mod is my giant 42" Lightbar mounted to the front of my Lex. I made it easily removable so it's not on all the time, but i put it on when i go run the hills right by my house and it's dark as hell up there. It gives me about an extra 80+ yards of visibility.
I have it wired to a rocker switch+highbeam switch, so you have to have the rocker switch active AND use the highbeam switch for the lightbar to turn on, so when im running in the hills all i have to do is let go of the highbeam switch to turn it off and not blind everyone and without taking my hands off the wheel.
I also make my own decals btw. The lightbar is as low profile as i can go without touching the bumper cover
Lightbar plus Halo projector headlights (I still need to get bumper painted, install sidemarker signals, and route exhaust to bumper)
Let me know what you think. Is it crappy or awesome or stupid?
Where did ya get the headlights from? Mine are turning yellow after every couple months and that's when I use the headlight restorer. No mods for me except blacking out the car and still in progress, still got to do emblems, door handles and grill.
10th Gear
I just replaced them a few days ago, i got them from ebay for $230, but they're called CCFL Halo projectors for 05-06 es330s and i converted them to L.E.D. H7 Low beams and L.E.D. H1 High beams so no more heat from H.I.D.s and Halogens to cause the yellowing, you should see the ones i took off, they were completely yellow.
Im very confident that its the heat from the halogens and HIDs causing the yellowing
I use the 3m headlight restoration kit with synthetic wax for the protective film. Haven't seen yellowing in years and I have a quad low beam projector hid set up with still 35 watt bulbs.
10th Gear
Im gonna have to look into that one! Im gonna try everything i can to not have my new lights yellow.
These are the headlights I want, black to go with the rest of my car but, pricey. They should work with my car and then I'll use the clear film protector. I'm not crazy about the halo's but, that's all there is unles I buy another pair and disassmble and paint everything black idk.
https://www.headlightsdepot.com/lexu...SABEgIMBfD_BwE
10th Gear
Those would be sick! Nice thing is, that if you don't like the halos, you can just snip the wire to their ballast or even wire them separately to your fog light switch if you don't always want them on, or maybe even wire them in with your signals.
https://www.amazon.com/3M-39008-Headlight-Restoration-System/dp/B001AIZ5HY/ref=mp_s_a_1_3?ie=UTF8&qid=1540691061&sr=8-3&pi=AC_SX236_SY340_FMwebp_QL65&keywords=3m+headlight+restoration+kit&dpPl=1&dpID=51sFOMZCpbL&ref=plSrch
and synthetic wax. https://www.amazon.com/gp/aw/d/B000PGEMQM?psc=1&ref=yo_pop_mb_pd_title
TheLexo93 (10-31-18)
I actually use to have a light bar but never liked the look of it on my car. Plus they are illegal in most or all states unless covered and can only be used off road. So I took it off, ended up doing a retrofit with morimoto d2s 4.0 and the rx350 projectors for a quad low beam, quad high beam set up. The switch for the high beams is wired to the fog light switch now. But I'm pretty satisfied with the results and dont really need a light bar anymore anyways.
I have tons of other mods, pretty ridiculous to be honest because I spent a little over 4k on modifications over the years. The retrofit alone was 1,060 dollars for the projectors, shrouds, bulbs, ballasts, wiring.
Maybe I'll make a thread on it in a couple days.
10th Gear
As you can see, i added 4 10" inch electric fans and also I have D2 Racing Coilovers Replaced the OEM hood insulation with my own aluminized insulation.
I also had to install another fuse block due to all the extra crap i added along with a relay block just beneath it
Painted A/C control bezel and this radio dash bezel millenium silver (to match the exterior) with a TRD badge to cover the oem clock hole.
carbon fiber dipped the gauge cluster wood piece and painted the rest glossy black
Carbon fiber dipped this part of the dash as well and painted all the vents gloss black for contrast
here is my exhaust i made, no muffler or resonators. Straight pipe for 3 feet then turns down
I insulated all of the doors and removed unnecessary oem insulation and garbage and sprayed it with that rough insulation stuff
This is what goes on that door and ultra dampens all noises and cuts down on road noise and eliminates all hollow sounds from the speakers, this is a very very thick rubber pad looking thing
i also made my own extra engine damper to help keep the engine still while running the hills in a lower gear, this shock bolts to a bracket i made for the transmission.
