ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   Catalytic system cleaner (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/901298-catalytic-system-cleaner.html)
ALi00989 Oct 5, 2018 04:34 AM
Hi there,
My car is 2003 ES300 and I watch Video on youtube explain the method of cleaning catalytic system by liqui moly cleaner and I do not know which hose in throttle body i can use, can some one help me, which hose ? Thank you
(sorry if there any spelling mistake because the English not my first Lang )
Lexmex Oct 5, 2018 07:12 AM
Welcome to the Club.
This is the product you are talking about, https://products.liqui-moly.com/cata...cleaner-2.html
You want the positive crankcase ventilation hose where the red rectangle is. Pull that and spray there with the engine on.
https://cimg1.ibsrv.net/gimg/www.clu...cee272b7c0.jpg
ALi00989 Oct 5, 2018 12:05 PM
Thank you very very much
VeryScary Oct 5, 2018 01:46 PM
Does this method work better than pouring it into the gas tank?
Lexmex Oct 5, 2018 03:28 PM
Better than in the gas, because it helps clean out the dirty air intake.
Hayk Oct 6, 2018 04:15 PM
*Follow up thread*
Poured cleaner in engine, engine make noise. Engine stop, no more start. Help....
LeX2K Oct 6, 2018 04:35 PM
What do you mean by "poured in" did you follow the directions on the container?
satiger Oct 7, 2018 06:05 PM
Did you pour and spray as instruction says?
How about draining and filling oil? .
mrzaima May 13, 2019 06:09 AM
Dear @Lexmex
I have just used it now and placed a small narrow tube in the bottle. I removed the last manifold air sensor and placed the other end of the tube in. Unfortunately it sucked the whole fluid within a minute or so. i forgot to keep closing for 30 minutes. I didn't see smoke coming out of the exhaust. immediately after i noticed that the economy usage data read 0.3l/h on idle, it used to read 0.6 or 0.7l/h. Does that mean a problem happened or i broke anything? and also would i need to repeat the procedure again as no smoke came out and didn't keep spraying for 30 minutes. I am really worried about that economy meter reading. As i was expecting a lot of smoke like the videos i saw, i drove a little away from home in an open area. now i parked it back home and will see later how the engine will run. Please advice
Lexmex May 13, 2019 08:30 AM
Originally Posted by mrzaima (Post 10516061)
Dear @Lexmex
Sometimes you get no to little smoke, have had that.
mrzaima May 13, 2019 09:34 AM
Thanks for your reply, and sorry to bother you again. What about the consumption that is too low
