ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   coolant flush (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/901134-coolant-flush.html)
harrisbaig Oct 3, 2018 09:12 AM
coolant flush
does it need a flush/ change at a set interval?
the fluid is very clear. no other cooling issues as well.
I have not had it flushed/changed for the 6 years under my ownership. no previous records available.
Lexmex Oct 3, 2018 10:19 AM
I change it every 100K or do it every time I need to change out the timing belt. I also had 3 bottles of Redline WaterWetter at that time.
Oro Oct 3, 2018 02:17 PM
I drain and fill the radiator every few years (40 to 60k). Easier than a full fluid flush and frequent enough to refresh critical chemicals. If it has been six years I would at least do that, especially in Texas where the heat is harder on the coolant. Toyota red is really easy to find these days.
HomerJay Oct 3, 2018 03:22 PM
It's also cost effective to buy undiluted coolant and mix with distilled/ demineralised water.
harrisbaig Oct 4, 2018 05:46 AM
is it an easy diy project?
Oro Oct 4, 2018 04:43 PM
Yes, it's easy. Rough outline:
a) open car at filler neck (when cool, not hot), and then the drain on the Radiator
b) close when draining stops.
c) re-fill at filler neck with 50/50 (or your desired ratio) pre-mix or mix of concentrate and distilled water. (I like 60/40 so I buy concentrate)
d) Run with heater on until the thermostat opens and level drops. Top-up and close system.
e) Check again after driving a day, and adjust reservoir level.
It helps if you do this with the car slightly nose-up or on jacks if you can, it helps air work it's way up and out. It is not absolutely necessary, though.
If you want to get more out/in at once, you can crawl underneath and open the block drains with sockets on extensions. they are on either side of the block.
Lexmex Oct 5, 2018 07:23 AM
These are the drain plugs and the plug for the radiator. Plug for radiator is at the bottom, one drain plugs is near the oil filter on the front of the engine and the other drain plug is behind the AC/Drive belts/pulleys.
https://cimg0.ibsrv.net/gimg/www.clu...fe9d813220.png
https://cimg9.ibsrv.net/gimg/www.clu...f5ad57c9dc.jpg
https://cimg1.ibsrv.net/gimg/www.clu...9a40934648.png
