ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   Does a K&N Filter improve sound? (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/898549-does-a-k-and-n-filter-improve-sound.html)
ZeRoSL Sep 4, 2018 08:53 AM
I used to have an LS400 and there was a cheap air intake mod to add a dramatic intake noise on WOT.
I now have an ES330 and realize that such a mod is not possible, but was wondering if I did replace the stock filter with a K&N would it make a difference in the sound?
I would assume not as the stock airbox is likely very muffling.
And yes, I completely understand that there are negligible or negative improvements to actual power most intake mods, but I'm willing to sacrifice a few ponies for a better noise on WOT
Thanks for any replies
LeX2K Sep 4, 2018 09:34 AM
If you want more intake noise remove the resonator inside the fender.
Lexmex Sep 4, 2018 11:53 AM
Agree on the resonator, the K&N filter alone won't do it. To get some real noise you do need the intake.
ZeRoSL Sep 4, 2018 12:48 PM
I may be asking too much, but is there any instruction to do this?
Lexmex Sep 4, 2018 05:15 PM
The resonator is located in front of the left front tire and you need to remove the plastic cladding of the wheel well to get what looks like a black box with rounded edges that has a tube that sticks out the top of it. There is a metal bracket with two bolts that holds it in.
ZeRoSL Sep 11, 2018 12:06 PM
thanks!, i'll keep this in mind if i decide to mess with it
Lexmex Sep 11, 2018 12:40 PM
This is a picture of that resonator.
https://cimg8.ibsrv.net/gimg/www.clu...513591dc18.jpg
