06 ES330 climate control screen is blank
Old 07-05-18, 06:09 AM
funcrusher
funcrusher's Avatar
Default 06 ES330 climate control screen is blank
Hey everyone. Been a while since I've logged in! I just got a 06 330 with 130k miles and I'm fixing all the little things. Soooooo my climate control buttons work perfect but the screen is completely blank. Common issue? Do I need to replace the entire climate control unit?
Old 07-05-18, 03:32 PM
FatherTo1
FatherTo1's Avatar
My wife's 06 with 125K miles has also developed some missing LED segments on the climate control display. For instance, instead of 72 degrees it wi show 12. Since the center console is all integrated, I am fearful that it all has to be replaced just to fix the strip of display. Honestly, not worth it on her 12-year-old car. If it became blank like yours then I might browse the local dismantler yard to see how much it would be to replace it yourself.
Old 07-06-18, 11:20 AM
funcrusher
funcrusher's Avatar
Weird, guess it's not a common thing and the only solution is replacing that whole unit! I'll wait a few days to see if anyone replies then track one down from a junkyard. Might as well replace all the bulbs behind it to.
Old 07-06-18, 12:02 PM
PFB
PFB's Avatar
Try tapping lightly on the display. You may get lucky.
Old 07-06-18, 03:13 PM
funcrusher
funcrusher's Avatar
No luck. Units are only $40 on eBay though .
Old 07-07-18, 10:31 AM
FatherTo1
FatherTo1's Avatar
I never even considered this. Thank you for the tip! I didn't realize the cost could be so low and definitely plan to go this route.
Old 07-17-18, 11:57 AM
funcrusher
funcrusher's Avatar
I've been calling junkyards and think I found one but a few questions...
My car doesn't have heated or cooled seats. Can I still use a climate control if it has those options?
What years will work on my 06? I assumed 02-06 but junkyards are telling me only 04-06...
Thank you.
Old 07-19-18, 06:07 AM
funcrusher
funcrusher's Avatar
Anyone??!
Old 07-19-18, 10:05 AM
Received 2,707 Likes on 2,292 Posts
Do some basic research! Looking at units on Ebay the ones with seat heater buttons have an extra connector the other connectors look the same. So they might be compatible maybe not why not just buy the proper unit. According to the part number the production date range is 06/2004-02/2006 but without checking using your VIN that may not be correct.
Old 07-20-18, 11:02 AM
funcrusher
funcrusher's Avatar
I actually stopped by the dealer. He told me a unit with seat heater/cooler buttons wont work. But any standard one from 02-06 will be fine hmmm.
Old 08-14-18, 08:18 PM
funcrusher
funcrusher's Avatar
Fixed it! I used an 03 with no issues so any year from 02-06 without heated or cooled seat options will work.
sippy2
08-04-17 08:45 AM
Bentley1
SC- 1st Gen (1992-2000)
11-03-04 04:14 PM
Quick Reply: 06 ES330 climate control screen is blank
