Painted winter rims graphite color
Just wanted to share what I did with my old ES300 rims on my 98 Lexus. I wanted a different look instead of the silver oem look, so I did graphite.
What I used-
What I used-
- 2 cans of Dupli-Color Graphite ($6.99/per can at mostly any auto parts store)
- 1 can of Rust-Oleum primer ($3.96 at Walmart)
- 1 can of Rust-Oleum 2x Clear coat semi-gloss ($3.86 at Walmart)
- sandpaper 150, 400, 1000 grit that I had laying around
- 5 medium box from Home Depot ($1.39/per box)
- Tac cloths
- Rubbing alcohol
- 2 sets of index cards from the dollar store
- painters tape
- Heat gun
- 3 coats of primer
- 5 coats of graphite
- 3 coats of clear
ikecalle (07-29-19)
Great job, thanks for sharing. Agree the index card use is very clever and a real timesaver!
How much time was required between coats? Lastly, how are they holding up going down the road?
whooodat (02-24-18)
WildES300 I wait about 10-15 minutes between coats give or take. I also used a heat gun as well that speeded up the process because it was around 30F here in IL when I did it.
After I did the rims I only had them on for like over a month before the head gasket started to go and sold the car. In the summer I rocked mint IS300 wheels that makes the car look great.
Ohhh that looks good, Ill probably do the same. I recently had some is250 wheels powdercoated for my es summer wheels and plan on using the stock ones for snow tires this winter.
