Timing Belt Replacement
Old 10-27-17, 06:37 AM
priscilla
priscilla's Avatar
Default Timing Belt Replacement
I recently inherited a 2001 Lexus RX300 with 100,000 miles. The timing belt has not been replaced and I've been told that I need to get that done before I bring it home to Vermont (the car is in Connecticut). The estimate I received to have it fixed in CT seems expensive ($991) and I'd prefer to have my local mechanic do the work. I'm concerned that I might damage the car by driving it 6 hours to Vermont.
Any input/suggestions/direction would be much appreciated.
Old 10-27-17, 06:56 AM
BDSL
BDSL's Avatar
Here are your options.
1. Suck it up and pay $991.
2. Get a transport company to transport the vehicle to Vermont.
3. Don't replace the belt and risk your life (and others).
4. Get another quote in CT.
Old 10-27-17, 07:24 AM
PFB
PFB's Avatar
You'll be just fine driving it to Vermont. No worries. The chances of the belt breaking are minuscule. And even if it does, your engine will just shut off with no damage.
So have a good trip.
Old 10-27-17, 09:13 AM
crwys
crwys's Avatar
At the very least remove part of the timing belt cover and check for age in the belt. I think you will be fine driving it though.
Old 10-27-17, 09:44 AM
PFB
PFB's Avatar
Naaa. . She doesn't need to do anything. She will be fine to VT and beyond. No need to spend money for nothing.
Old 10-27-17, 09:59 AM
Oro
Oro's Avatar
Originally Posted by PFB
You'll be just fine driving it to Vermont. No worries. The chances of the belt breaking are minuscule. And even if it does, your engine will just shut off with no damage.<br /><br />So have a good trip.
<br />
This. Don’t let scaremongering influence you or your pocketbook. Enjoy a nice fall drive and deal with it comfortably at home.
Old 10-27-17, 10:51 AM
Received 2,707 Likes on 2,292 Posts
A broken timing belt is not a perfectly safe, risk free failure. Turn the key off at random while driving, is that safe? A broken timing belt is basically the same.
Old 10-27-17, 12:43 PM
nsghtbrwry
nsghtbrwry's Avatar
Yeah, I vote crack open the top timing cover at least and check for big cracks in the belt. Little cracks or no cracks should get you home.
Old 10-27-17, 06:53 PM
crwys
crwys's Avatar
I didn't say pay a shop to do it. It is incredibly easy to remove the timing belt cover. I'm assuming the op can do it or knows someone who can. If not a shop would charge 30-60$?
Also there's been multiple reports of a timing belt breaking and causing engine damage for these engines.
Old 10-27-17, 09:29 PM
Oro
Oro's Avatar
Really? Because in a lot of years here and at Toyotanation.com, I cannot recall one or have heard mention. Usually it is taking them out above 150k and them looking fine that appears. I have seen ones well north of 200 break, but never cause valvetrain damage. I do mine at around 100 but don’t sweat a little bit either side, it’s just not that big an issue and the time factor never seems to matter versus mileage.
Old 10-28-17, 06:36 AM
crwys
crwys's Avatar
There was actually a thread here a few months ago. A simple Google search will show you the rest.
I think the OP is fine to drive but should also know of the risks even if they are slim.
Old 10-28-17, 07:11 AM
PFB
PFB's Avatar
As I said already, I'm not concerned about her timing belt breaking, I do recommend however that she join AAA road side service. It's always good to have. Even for such simple things as a flat tire.
Old 10-28-17, 11:15 AM
Oro
Oro's Avatar
There was actually a thread here a few months ago. A simple Google search will show you the rest..
Love to see it. Link?
I HAVE searched but no stories of belts snapping at lower mileage.
Old 10-28-17, 11:01 PM
crwys
crwys's Avatar
I wasn't talking about low mileage, I was talking about engine damage when the belt breaks.
Old 10-29-17, 08:51 PM
Oro
Oro's Avatar
It would be good to see that. All of the reported ones have had no vt damage. But presumably there may be a high rpm range that is possible. Link?
Quick Reply: Timing Belt Replacement
