Auto window up timing/relearn? (3es)
So my mom's 01 coach edition's window regulator cables snapped, I grabbed a regulator and motor setup from a 99 from the junkyard, but it turns out the motors were different so I took the regulator cable pulley apart and stuck it in the 01 motor since it worked fine.. problem I'm having is the window goes up all the way with auto up, then it like "bounces" and goes back down halfway.. anyway know how to fix this? I tried "relearning sequence" by holding the power button up and stuff for a while but it doesn't work
I think the window did this before I changed the regulator when the regulator broke, thanks! |
