96 es300 wont start
Old 07-21-17, 08:37 PM
AutoMaticI
AutoMaticI's Avatar
Default 96 es300 wont start
I replaced the power steering pump, and all the lines. I put the car back together and it won't start. I do have a code reader as the check engine light is on, however, I'd like some help with that. attached is a pick of the results. What is that thingmajig by the engine that says diagnostic.
Thanks everyone.
Old 07-21-17, 11:19 PM
nsghtbrwry
nsghtbrwry's Avatar
Those are just the smog (or "drive cycle") monitors. You need to read codes.
If the car hasn't started, the CEL comes on when you turn the key to ON as part of the bulb test for the instrument cluster.
You sure nothing else was unplugged during the P/S pump job? The crank position sensor is down there, if it was unplugged that would definitely cause a no-start.
Mcbry7
08-28-18 06:49 AM
Camsdad68
03-08-14 09:00 PM
bigge31566
02-20-14 01:10 PM
Bizangel
12-09-13 05:14 PM
regorih
10-22-12 08:31 AM
Quick Reply: 96 es300 wont start
