ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   Oil filter adapter nut size (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/862301-oil-filter-adapter-nut-size.html)
Mdantuma1 Jul 14, 2017 04:10 PM
I tried all the way up to 22 mm and then 24 mm then I read 30 mm. Please help. It's the nut behind oil filter. Thanks.
Oro Jul 15, 2017 02:05 AM
You are trying to remove the oil filter stud itself?
I have to ask why? Is it damaged or broken? Or you are trying to change it to a different size (which is the common reason for removing them)?
Because the fact Toyota uses a 3/4 x 16 stud is a total gift for American owners, it gives us access to a vast array of high quality filters for very cheap vs. most asian metric filter stud sizing.
