Wheel bearing DIY anywhere?
I have had some increasing front shimmy at specific speeds and on braking. I've lifted it and tested and it appears to be a loose wheel bearing on one side, possibly loose outer tie rod end on the other. Lower ball joints seem rock solid despite 275k miles.I want to tackle the wheel bearing first - partly to neck things down and also because I can get some quality ones (hub/bearing assembly) locally tomorrow and get on top of this. I have all the necessary tools and assistance available. (Have rebuilt a few 4wd hubs and some AWD hub in the past, have a separator for the joints, press for the bearing, retired ex-machinist parent with other great tools for extra eyes and hands. )
Anyone have advice or a good how-to that is car-specific? Looking at the build diagrams, this is a slightly different animal than the RWD and AWD hubs I've torn apart In the past.
...and this link is very handy if you are not getting the bearing and hub done with a hydraulic press, but rather choose to do it yourself with a cheap Amazon or eBay FWD bearing kit: https://axleaddict.com/auto-repair/d...ng-replacement
My word of warning: whatever the axleaddict article says, don't use an impact wrench to drive the wheel bearing in. I can't say for sure that's what was the problem, but I replaced bearings and hubs on a family member's '95 Camry with two Raybestos kits that I drove in using my electric impact. I stopped very quickly after they weren't going in anymore, but they both failed on the first test drive (100 mile round trip, failed at 75 miles). Replaced them both with Timken kits (was the OEM bearing inside a Timken box), and that time drove them in with an extending 1/2" ratchet. Has been working great for 20k.
Like I said, I can't blame the impact conclusively because what I see is that Raybestos' parts quality has been going downhill, but I wouldn't take the chance. HTH
EDIT: Read back, missed that you have a press. Never mind about the FWD bearing toolkit
Thanks, that was helpfuly. The TN one was very thorough. I did this and it was relatively uneventful. The car is VERY smooth now, it was making no noise and I had did not appreciate what was going on for too long.
I am unclear why he is scribing the arm for the two strut bolts; mine is not in any way adjustable - perhaps some are. Rigging a support to hold the assembly square in the press to get the hub assembly and then bearing out was a real chore. It took everything the press (12 ton) had to give to get the bearing out; realy in there firmly. Interesting in the video he said at the shop the 10 ton couldn't do it. I didn't see the video link before I did the job; it would have saved me a little time as it was unclear to me at first to press the axle spindle OUT, then the whole bearing inward. That was, as usualy from him, a nice video.
Try this video. https://www.youtube.com/watch?v=1NbcVKxhlTA
Just did a front bearing on my Toyota Highlander. I'm pretty sure it's almost exactly the same for my ES300.
You're right, getting the knuckle properly mounted in the press is a chore because of its weird shape.
We had to take the knuckle to the neighbor's shop to use a 20 ton press to get it out. The 10 ton didn't do it, even after heating it up really hot with the torch.
BTW your video is terrific. Just a little lacking on using the press.
chuyrobles
ES - 5th Gen (2007-2012)
15
07-10-18 11:09 AM
silvergs79
01-16-10 11:22 AM
