ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   96' Front-Left Door lock actuator question. (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/837973-96-front-left-door-lock-actuator-question.html)
Cloxe Oct 27, 2016 06:47 PM
so my key unlocks and locks all the doors but the most important one... of course it does. My drivers door!
if I click the lock/unlock button on my key fob it makes the drivers door lock twitch but not change position. So I assume it's weak.
if I purchase this and attack it to the rest of y lock assembly will it fix the drivers door remote lock/unlock?
http://m.ebay.com/itm/272160668996
thanks!
-Cole
LeX2K Oct 27, 2016 07:58 PM
The Camry actuators are not the same as the ES, and if I recall correctly the front ones don't have an actuator that you can buy separately you'll need to grab the entire latch assembly.
FYI I've been able to revive them by removing and washing with brake cleaner then lubing. Never done it on your year ES though.
Cloxe Oct 27, 2016 10:11 PM
Thanks. I will try this
