1999/2001 es300 p0500
My 1999 ES300 is having some electrical issues, won't last more than 2 days on a charge without the battery dying since I purchased it. Today I finally got around to do a parasitic drain test. ECU-B is drawing 75 mA. So, I pulled the fuse. When I started the car up, ABS light was on, shift lock didn't work, and the CEL was on. Put the fuse back in, the SRS light is blinking.
Speedometer doesn't work, code is P0500. The engine and transmission have about 45-50K on them, pulled from a 2001 ES300. The car has 156K on the body.
Ideas? Thoughts?
Ideas? Thoughts?
No one? Bump
Update time, I found that the driver's seat memory button "SET" was stuck on. Cleaned it up, hopefully won't be draining the battery anymore.
Now, I've spent 2 hours looking for the speedometer sensor. I can't find it. I've undone the air box, battery, cruise control module, traced all the harness wires going to the transmission, and I'm frustrated.
Can anyone help?
Can anyone help?
The speedometer sensor is located underneath the air box. There are two identical sensors. This the the part
Follow this link https://www.clublexus.com/forums/rx-...ode-p0500.html . Look at post 3 for a picture of where the speed sensor is located. The one you are interested in is labeled 2. The picture is from an RX but it is the same in the ES.
Sorry I can't help with your electrical problem.
http://www.amazon.com/Dorman-917-603-Transmission-Sensor-Toyota/dp/B003SZ3JC0?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_detailpage_o04_s00
The speedometer sensor is located underneath the air box. There are two identical sensors. This the the part http://www.amazon.com/Dorman-917-603...ilpage_o04_s00
Next steps are to pull ABS codes manually, then reset ABS computer. If it comes back, then can narrow it down more. I will check resistance in both speed sensors. If > 560 <680 ohms, they are good. One post in the RX DIY P0500 said his was 63x ohms, both were good.
Do you have any other symptoms?
Probably not, but it probably depends on the signals that the sensor is outputting. When I had this problem, the right rear tone ring disconnected from the spindle. Thus the information the sensor was outputting caused the ECU to issue the P0500 and stop the speedometer from working.
Your description causes me to think about if I have a bad wheel sensor, those have 156K on them. If a wheel sensor wasn't reading and your speedo wasn't working correct?
My sensor was working but because the tone ring was (sometimes) rotating independently of the spindle/wheel the data it was sending to the ECU was bogus. I suppose the data was so different from the other inputs that the ECU was programed to disregard all speed data and issue the P0500 and stop the speedometer from working. My speedometer read zero.
Have you had any work done on the wheels, or hubs or bearing that might have caused the problem?
Is your ABS working?
I'm not sure what to do now??
Do I have a bad instrument cluster?
When I was doing the parasitic drain test, I pulled the ECU-IG fuse under the dash. I put it back into a dummy spot, and not back into the correct location. Put the ECU-IG fuse back in the correct location and everything works.
Thanks for everyone's help.
No I'm guessing the ECU takes inputs from all its speed sensors and does some sort of comparison. Then based on its programing takes some action. For instance if a wheel sensor isn't reporting anything the ECU could assume it's a bad sensor and just ignore it as it relates to the speedometer. In my case, because the tone ring was rotating independently of the wheel, the sensor was probably reporting random speeds, some being higher and some being lower than the actual speed. Perhaps under those conditions the programmers decided it was unsafe to report any speed to the speedometer. Therefore it set P0500 and turned off the speedometer as well as set abs error code 11 and 33. This is pure speculation on my part because I have no knowledge of the internal programing of the ECU.
Well, an update. I'm feeling retarded
