ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   Starting Car Twice (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/817242-starting-car-twice.html)
offremike Mar 21, 2016 07:17 AM
Starting Car Twice
Hello.
I've had my 1999 ES300 for almost a year now and what I haven't been able to figure out just yet is one of the issues I'm having. SOMETIMES, not all the time, but sometimes when I start my car, it won't start until you try it a second time. I have had a tuneup, my mechanic/cousin noticed the starter was replaced and there's nothing wrong with the spark plugs. I've replaced the knock sensors, Variable Valve Timing Solenoid (2)*and two of the O2 sensors since having the car. So I'm not completely sure what the issue could be at this point.*
mitmaks Mar 21, 2016 09:13 AM
Hows the battery, have it load checked.
Battery terminals, any corrosion on them, are they cracked and make a bad contact, are you able to move them by hand?
offremike Mar 21, 2016 09:24 AM
Havent checked it in a couple weeks but it's been an issue for months and I've had the battery checked within that time and was told by more then one person that it's in good shape, BUT I do have intentions to change the battery with a yellow top.
If that's not the cause, what else do you think it might be? I have 4 check engine codes that i plan to address, but half of them have to do with evap.
BDSL Mar 21, 2016 12:43 PM
When you said it doesn't start, does the starter crank? Or starter cranks but engine doesn't start?
offremike Mar 21, 2016 01:40 PM
The second. Sometimes it starts on the first try, sometimes it starts on the second. I never have to do it more then twice though. I've had two other people (mechanics) start my car and it happened with them, so i know its not the amount of force (or lack of) that I'm putting into it. When i was getting my remote starter put in, the guy who did it mentioned it as well but it wasn't bad enough to prevent him from installing it.
BDSL Mar 22, 2016 02:14 PM
My question was "Did it crank...the starter".
offremike Mar 22, 2016 03:59 PM
Crank? I honestly don't know what you mean by that. I'm not that good with cars (yet).
BDSL Mar 22, 2016 05:46 PM
Does your motor turn when you turn the key?
Or you hear nothing turning when you turn the key?
offremike Mar 22, 2016 07:14 PM
Ok, yea, I was mentioning that before. It starts, but doesn't fully run. So when i turn it to start, it should automatically run, but what it does is basically., as if you were about to start the car then halfway into you doing that you just switch it to "on" instead. When i try it a second time, it will always work if it hasn't worked the first try. Hopefully that made sense.
BDSL Mar 23, 2016 06:22 AM
Not making sense.....
mmatheny Mar 23, 2016 06:55 AM
Maybe bad ignition switch. Intermittent.
PFB Mar 23, 2016 01:00 PM
Or a bad neutral switch. Or even a bad key. If you have another one, try another key
Also, try starting it in Neutral
At least those are quick and easy things you can try, with nothing to loose. No parts or labor required to try.
