how to use electric accesory for es330?
Old 11-29-15, 09:31 PM
moremore78
moremore78's Avatar
Default how to use electric accesory for es330?
just bought a used lexus es330, can anyone tell me how to charge GPS or any other electric accessory using cigarette lighter or power outlet of this car? It seems I can't use ordinary car chargers on this car.Thank you so much.
Old 11-29-15, 09:39 PM
808mcv20l
808mcv20l's Avatar
First thing that comes to mind is to check fuses, then get a multimeter to see if you are getting power at all. If not, then check the connector that goes to the cig lighter/power socket.
I wonder if the power socket is usual on the 330s, this is the second post I've seen for the same issue recently.
Old 11-29-15, 11:06 PM
moremore78
moremore78's Avatar
I AM AFRAID IT IS NOT USUAL.I CAN'T FIND THE RIGHT CAR CHARGER FOR LEXUS ES330.
Old 11-30-15, 06:46 AM
crwys
crwys's Avatar
Any car charger should work. I've used many different chargers.
Old 11-30-15, 04:06 PM
Corkman
Corkman's Avatar
I bought a 05 ES330 this summer and and one of these. works fine in lighter outlet. It has two UBS ports for charging and Bluetooth for phone/music. Hope this helps...
Amazon.com : Abdtech Wireless In-Car Bluetooth FM Transmitter with 4.2A/21W 2-Port USB Car Charging Hands-Free Calling MP3 Player : Electronics Amazon.com : Abdtech Wireless In-Car Bluetooth FM Transmitter with 4.2A/21W 2-Port USB Car Charging Hands-Free Calling MP3 Player : Electronics
Old 11-30-15, 06:57 PM
speedkar9
speedkar9's Avatar
My 12V outlets work normally in my ES330, it powers two dashcams and a GPS just fine.
Old 12-02-15, 10:45 PM
Chocolate
Chocolate's Avatar
This... check your fuse boxes. There are several spares you can try.
Old 12-03-15, 07:59 PM
moremore78
moremore78's Avatar
i have just bought a GPS, and the charger for the GPS(See the pic) does not fit the power outlet(see the pic).This GPS also has a USB charger.can anyone tell me what kind of car charger do I need to buy in order to use this GPS?THANKS A LOT.I noticed that the bottom of both outlets are flat,and doesn't seem to fit the ordinary car chargers which has a pin at one end.
Old 12-03-15, 08:00 PM
moremore78
moremore78's Avatar
Smile
really?can you send me a link of the charger you have used?is the power outlet look same as mine?thank you
Old 12-03-15, 08:02 PM
moremore78
moremore78's Avatar
thank you so much.Is the power outlet look the same as mine? The charger you recommended also has a pin at one end, and I noticed that the bottom of the power outlet is flat. Does it matter?THANK YOU
Old 12-03-15, 09:09 PM
Corkman
Corkman's Avatar
Yes mine looks just like your photo. The couple different devices we use all have taped ends, maybe that helps. The charger you have looks like an older one I use to have. Does the end unscrew and have a fuse in it? Also my lighter socket only works with the key turned on, which I like because I never have to unplug things....
Old 12-10-15, 02:03 PM
moremore78
moremore78's Avatar
Thank you so much for your suggestion.I just got the charger that you recommended and it works pretty well on my es330. Thanks a lot
Old 12-10-15, 04:59 PM
Corkman
Corkman's Avatar
Glad to hear we solved the problem. My car is missing the the ash insert in the ash tray. The car was never smoked in, so who knows what happened to it. But I want to see if I can grab a cheap one somewhere and epoxy the top 2/3rds of something like this to hold my phone and can be popped in and out.
Amazon.com: Macally MCUP Adjustable Automobile Cup Holder for iPhone, iPod, Smartphones, MP3 and GPS - Black: Car Electronics Amazon.com: Macally MCUP Adjustable Automobile Cup Holder for iPhone, iPod, Smartphones, MP3 and GPS - Black: Car Electronics
I let you know how that works out.
Mike
h42ka1
04-27-18 06:54 AM
ltd76gold
01-19-17 08:23 AM
ESTO
ES - 5th Gen (2007-2012)
11-21-06 02:06 PM
Quick Reply: how to use electric accesory for es330?
