ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   Speaker sizes (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/803817-speaker-sizes.html)
Toropoki Nov 19, 2015 05:44 PM
Speaker sizes
What are the speaker sizes for the 1998 ES300 stock stereo ?
Skip the tweeters just the main ones in the doors and the sub woofer in the back.
Did I miss any?
808mcv20l Nov 20, 2015 05:43 PM
6.5" in the doors, the sub is 8" but don't quote me on that.
Power6 Nov 23, 2015 09:34 AM
I think the ES is considered 6.5" in all doors, because from an aftermarket audio standpoint you can mount a 6.5" there. In actuality the front door speakers are larger than the rears. The fronts might be more like what the aftermarket calls a 6.75" speaker, or the rears are like a 5.25" with a particularly large mounting basket.
Anyways just keep in mind it is easier to mount a larger speaker in the front doors than the rears. The sub is an 8" and the basket is integral to the mounting plate that bolts to the deck and also mounts the grille on top so if you are thinking of replacing that with aftermarket it takes a little customizing.
808mcv20l Nov 23, 2015 01:17 PM
Can you tell me if the rear speaker mounting holes are the same as the front aside from the size of the speakers?
I found something particularly interesting.
http://www.ebay.com/itm/6-5-Speaker-...FVAqO9&vxp=mtr
That looks like the adapter brackets that would fit in the front speakers, trying to confirm if the rear mount holes are the same if this same adapter would work for the rears as well.
