ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   05 ES330 HID lights? (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/797764-05-es330-hid-lights.html)
flblue Sep 17, 2015 03:13 PM
Best place to purchase them? Ebay?
They have gone yellow on the INSIDE, not the usual yellowing on the outside so they can't be buffed or polished.
Moisture has somehow got on the inside of the lenses and I don't see how it can be fixed without replacing them. They work fine they are just an awful dirty yellow color now.
Thanks in advance.
808mcv20l Sep 17, 2015 03:33 PM
they all seem pretty expensive the used OEM ones.
I think you are better off buying a set of aftermarket new HID housings off ebay TYC brand? since you only need the housings, you can transplant your bulbs and ballasts to the new housings.
Chocolate Sep 17, 2015 06:08 PM
eBay. Stick with the OEM projector housings.
flblue Sep 18, 2015 09:23 AM
is this what I'm looking for? Will these work?
http://www.ebay.com/itm/Anzo-Headlights-121173-Projector-With-Halo-Chrome-Housing-2005-2006-Lexus-ES330-/391256689557?hash=item5b18b74b95&vxp=mtr
Chocolate Sep 19, 2015 04:05 AM
Originally Posted by flblue (Post 9187705)
They will function, yes, but they use an inferior 2.5" projector and crappy lens and reflector bowl instead of the better quality 3" Koito projector and lens. You want a set of new/used OEM projector housings, so use "OEM" in your search and get the right kind (Halogen or Xenon).
Chocolate Sep 19, 2015 04:06 AM
Do you have halogens or Xenons?
Check my posts in these threads:
https://www.clublexus.com/forums/es-...id-lights.html
https://www.clublexus.com/forums/es-...ior-led-s.html
