05 ES330 front left knocking noise. Please help.
Old 05-06-15, 10:16 PM
jseeley94
jseeley94's Avatar
Default 05 ES330 front left knocking noise. Please help.
I have a very loud knocking noise coming from the front left of my ES.
A few months ago I hit a fairly large pothole on the highway. Hard enough to cause a large bubble in the side of my tire. Which has since been replaced.
Since then I have had a knocking noise coming from that side. At first it wasn't bad. It was only noticeable when going over bumps or other potholes. It has since gotten worse. It very loud and very noticeable even when driving on seemingly smooth roads.
Does anyone know what could be damaged?
I don't know the most about cars but enough to do the job myself as long as I can figure out what's wrong.
I just replaced all my rortors and brake pads and couldn't see anything that looked off to me.
Any help/advice would be greatly appreciated.
Old 05-07-15, 09:43 AM
RXGS
RXGS's Avatar
Could be a strut but try looking at the swaybar endlink first
Old 05-07-15, 04:28 PM
ES300NZ
ES300NZ's Avatar
rock the car from side to side. I bet the shock is floating free in the bottom of the strut housing, happens all the time. I'd explain why but it's quite boring, if that knock is present during quite violent side to side rocking (by you), it might be time for a new set of front shocks (always replace in pairs).
Old 05-08-15, 06:13 AM
KLF
KLF's Avatar
I would echo checking the swaybar endlinks. You have to jack up both sides of the car (or put it on a lift) so both wheels are unloaded and the bar is not twisted, and it can still be hard to find.
Old 05-11-15, 10:30 AM
GRUMPY617
GRUMPY617's Avatar
I just changed all my struts and sway links. AND still the same knocking sound still there. And i also have the noise from the rear.
Old 05-11-15, 10:44 PM
Oro
Oro's Avatar
Also consider the upper mount.
It could have been impacted hard enough to wreck the bearings and/or race. This is a common failure on cars driven a lot in urban areas with bad roads from the jackhammering from potholes. If the endlink diagnosis doesn't show the problem, look at that. FYI, best not to use aftermarket mounts (Monroe, KYB). The factory ones are pricier but have a much lower failure rate than the aftermarket ones.
Old 05-12-15, 12:34 AM
ES300NZ
ES300NZ's Avatar
Lower wishbone/arm bushes, body side.
Old 05-12-15, 05:31 AM
BDSL
BDSL's Avatar
1. Swaybar endlinks
2. Ball joints
3. Tie rods
4. Strut mounts
lexusls4
12-05-13 07:44 AM
pegaleets
Suspension and Brakes
07-25-07 08:29 AM
arlink70
11-01-06 07:45 PM
allerton
05-19-06 08:24 PM
bigsax
01-23-04 09:53 AM
Quick Reply: 05 ES330 front left knocking noise. Please help.
