Help!
Old 08-05-14, 09:27 AM
sarahsutto
sarahsutto's Avatar
Default Help!
I just bought a 1998 es300 about two weeks ago. On sunday I noticed that the floor board behind the passenger seat was wet. The carpet was soaked. It doesnt smell but it has a blue tent to it. I was thinking water pump? Help!
Old 08-05-14, 09:50 AM
BDSL
BDSL's Avatar
What colour is your coolant? Toyota use "red" coolant unless the previous owner switched to "green" coolant. Is it your windshield fluid?
Old 08-05-14, 10:07 AM
sarahsutto
sarahsutto's Avatar
I thought about the windshield fluid but its empty.. any my coolant is green.
Old 08-05-14, 02:38 PM
lostape45
lostape45's Avatar
Has it been empty? Because if it wasn't before, it must've leaked out.
Old 08-05-14, 04:14 PM
sarahsutto
sarahsutto's Avatar
Yeah. Its been empty since I got the car. I guess ill go buy some and put it in there and see what happens. But how would that end up on my back floor board
Old 08-05-14, 06:51 PM
sarahsutto
sarahsutto's Avatar
Yeah. Its been empty since I got the car. I guess ill go buy some and put it in there and see what happens. But how would that end up on my back floor board?
Old 08-05-14, 07:17 PM
SharpGent
SharpGent's Avatar
Sounds like the evaporator core for the A/C. I come from a long line of GM cars, so I don't know whether it's the same in the Toyota, but the Evap core is the culprit when the passenger floor is soaking wet in those cars. I've replaced hundreds.
Then again, we didn't have to take the entire dash out the replace that bad-boy. According to this thread, this person did. https://www.clublexus.com/forums/gs-...y-project.html
Don't run the A/C or defroster for a few days and see if things stay dry. If so, then you have a leaking Evap.
Whatever the case, good luck to you.
Old 08-06-14, 08:02 AM
afang
afang's Avatar
Did you rule out stopped up drain lines from the sun roof?
Old 08-06-14, 07:41 PM
sarahsutto
sarahsutto's Avatar
Ill try that this weekend. Its kinda hard have no ac in 100 degree weather with a child. Thank you!
Old 08-06-14, 07:42 PM
sarahsutto
sarahsutto's Avatar
No. How do I check that?
Old 08-06-14, 07:43 PM
3ztwint
3ztwint's Avatar
I second the EVAP core causing it
Old 08-06-14, 09:19 PM
afang
afang's Avatar
When my sunroof lines were stopped up I had the dealer fix the problem. I think you need to look for the drain ports and blow them clear with compressed air. After a rain storm My rear floor carpet behind the passenger seat was soaked.
Old 08-07-14, 12:14 PM
sarahsutto
sarahsutto's Avatar
Ohh that may be it. We had some rain last week and thats when I noticed it. Thanks!
DREED2017
16
04-17-17 12:29 PM
ThumperPup
ES - 5th Gen (2007-2012)
09-24-13 08:56 PM
foe84
11-13-12 03:49 PM
shikbas
01-11-08 05:18 PM
Philly RX
RX - 1st Gen (1999-2003)
01-08-06 06:33 AM
Quick Reply: Help!
