cigarette light don't work
Old 07-18-14, 06:50 PM
sereousl
sereousl's Avatar
Default cigarette light don't work
How to remove cigarette light? N do I need a specific one for my es300 or can I use a universal
Old 07-18-14, 11:35 PM
Tripoderik
Tripoderik's Avatar
Like the cigarette lighter (the assembly itself)??? You would remove the trim piece below the ac controls but above the ashtray - with a flat head, gently pull it out. Then remove the bezel trim peice around the shifter to reveal two screws. In an upward motion towards you, pull out (with the shifter in D1)
You most likely just popped a fuse. Why are you replacing the outlet?
Old 07-19-14, 11:56 AM
sereousl
sereousl's Avatar
I replace the fuse not still not working but their power coming out of it and the assembly is broke but I have a hard time finding some to do because I am scared I would break something. Show me how or show me how to add a universal outlet instead of just replacing that piece n kill the hard work
Old 07-20-14, 08:59 PM
LexusElite
LexusElite's Avatar
I thought the cig lighter was in the ash tray right in front of the shifter? You should be able to pop it out of the tray and replace it.
Old 07-21-14, 05:14 AM
Tripoderik
Tripoderik's Avatar
There are 2 outlets usually, the one in the ashtray and the one in the center console depending on the year (my 97 has 2) not sure about 92-96? That being said it is most likely a fuse. There are two different fuses. CHECK BOTH. If the assembly does need to be replaced it is not hard, search this forum for radio removal or aux input. The steps needed to remove the radio have included pics to get you far enough to see how to remove the ashtray, it'll feel uncomfortable at first but it is easy.
ronolexus
12
05-19-14 04:44 AM
booga
SC- 1st Gen (1992-2000)
07-04-11 01:23 PM
DaytonaSTi
11-09-09 06:07 AM
tskolak
07-10-07 02:02 PM
GSXRAWD
GS - 1st Gen (1993-1997)
02-11-04 02:05 PM
Quick Reply: cigarette light don't work
