ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   Climate Contol Panel Out (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/706775-climate-contol-panel-out.html)
JHM Aug 24, 2013 02:24 PM
97 ES300 Climate Control Panel went blank. Radio works and clock. Referencing other threads checked fuse for cigarette lighter and it is good and no coins down in there to short out.
So, is there another fuse that is associated with that module?? Can that module just "go bad" out of the blue? Any suggestions on fixing the problem as it's August and about 90 Degrees today :(
Hayk Aug 24, 2013 03:18 PM
I would test all fuses first. Then I would pull the radio with the HVAC controls and try to check for power with the key on. Get a voltmeter.
JHM Aug 25, 2013 06:32 PM
Not too savvy with cars, but would you know which fuses would be related to the Climate Control System on the 97 ES300?
Hayk Aug 25, 2013 09:45 PM
No idea. I would start by looking at the fuse box markings by the steering wheel. The one that's behind the little storage compartment.
