ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   How do I replace my light bulbs? (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/70664-how-do-i-replace-my-light-bulbs.html)
carfanatic Jan 14, 2003 02:08 AM
OK...i know this is gonna sound stupid...but i want to replace my DTR lights with maybe a PIAA or Silverstar inorder for the slight blue tint to make it white rather than yellowish...but after i popped the bonnet up...i look at the placement of the high beams wiring and stuff...WAY too far in for my reach. Im a pretty big guy and my hand isnt the smallest out there...I had quite some difficulty even reachin the actual wiring..mind you mine's a 99...so i dunno what to do now...i dont want to have to go to an actual mechanic...but i also dont want to compromise the bulb life by fiddling around tryin to get it back in...so i'm in a dilemma now...what should i do? just give up?
steviej Jan 14, 2003 02:03 PM
Where in MA are you?
If you are near Boston or the South Shore, I could show you.
steviej
LEXBERG Jan 17, 2003 03:17 PM
can you guys post an install with instructions, I'm getting ready to change my headlamps as well..........
steviej Jan 17, 2003 05:55 PM
You probably won't see it here. Carfanatic has been banned.
If you are just changing bulbs or if you are converting to HID, do a search, most of you answers will be found in previous threads.
The owner's manual is not that descriptive in the changing of said items. Haynes has a shop manual for 97-01 ES 300, Camry, Solara, Avalon.
try www.amazon.com, do a book SEARCH, plug in ES 300.
Last I looked it was less $20. Previous experience has found these to be very informative.
steviej
