1997 Es300 Catalytic converter
Old 08-14-13, 02:16 PM
navdeepasi
navdeepasi's Avatar
Default 1997 Es300 Catalytic converter
Hi all,
The flex pipe on my car is leaking big time. However it's been cut out once and replaced before, so I need to change the whole front pipe (down to the catalytic converter). I'm having a hard time finding the part. It is a FED/Canada emissions and the car is built in Japan (vin starts with JT). I've seen many variants of the front pipe with catalytic converter that come with 2 flex pipes, and some that have 1 flex pipe. The current one on my car has 1 flex pipe. One parts guy told me that its a dual cat, and there shouldn't be only 1 flex. While others said the correct version has 2 flex pipes. Does anyone know which one is the correct one for this car?
Thanks,
Nav.
Old 08-14-13, 04:03 PM
navdeepasi
navdeepasi's Avatar
Sorry that should say that there SHOULD be only 1 flex, not shouldn't. One version has one flex and a small cat, and the other has 2 flex pipes.
Old 08-14-13, 06:42 PM
Hayk
Hayk's Avatar
I used the Walker CA emissions Y-pipe and it only came with one flex pipe. The fitment wasn't great, so I don't recommend it.
Old 08-14-13, 09:25 PM
FLYAIRWHIT
FLYAIRWHIT's Avatar
I purchased the magnaflow pipe for mine...the fitment was okay, but be prepared to remove the bottom bracket as it will not fit with it installed. Also, every stud that bolted to the pipe broke, so buy new exhaust manifold studs ahead of time. Your studs may be okay, my car has over 400k miles (I kid you not), so my studs may have been a little fatigued. Good luck!
Old 08-15-13, 06:25 AM
Mythotical
Mythotical's Avatar
FWIW When I had to replace the engine in my Ca 98 ES I got a donor from a FED 96 ES and the collector pipes out of a Fed 98 Camry. The flanges fit perfectly and I had the pipe cut off as close to the cat as possible. Then I just had to cut off my pipe I cut it about 8" back from the first hanger and there the Camry pipe fit over the inner wall and under the outer wall of the Lexus exhaust perfectly. Then I welded it up and presto. It was way less money then replacing the cat at only $25. Not to mention if you cut the upstream cats out you can sell them on ebay for scrap platinum recovery for about $60. So it's like getting paid to fix your own car.
Sryost85
01-25-15 07:25 PM
2012IS250
Performance
08-21-14 12:49 PM
Bedore
01-21-11 06:12 PM
brandon524
07-19-09 06:02 PM
LexSCthree
Performance & Maintenance
11-15-08 10:16 PM
Quick Reply: 1997 Es300 Catalytic converter
