Acceleration
hey everyone, just bought a 03 es300 and when i push on the peddle it just wants to take off. I have to easily push down to make it take off normally. very annoying. no check engine lights. any help would be great! thanks
High idle ?
I wonder if the car is idling too high. Your idle speed should be between 630 and 730 rpm's when your stopped. If it is higher . . . for example 1250 or 1500 rpm's . . . and you take your foot off the brake . . . the car will surge forward. Just a thought.
It's the DBW programming. Not much you can do. The throttle tip-in is programmed high, to give the effect of a powerful motor.
Try resetting the ECU, by pulling the battery cables. |
Yepp, time to reset the ECU. Disconnect +/- battery terminals for about 60 seconds.
When driving again it will be jumpy temorarily but,will now learn your softer, less aggressive driving style. |
It's the DBW programming. Not much you can do. Do all the newer Toyota's and Lexus cars now have DBW ? |
| All times are GMT -7. The time now is 12:15 PM. |
