ES 250 junkyard find
#31
Forum Administrator
It's listed as 250ES but I put that in and found a bunch, maybe you'll get lucky and there will be one near you
#32
Go to http://www.car-part.com/
#33
Does the odometer work? Speedo cable you can get from a generation 2 Camry. FYI the speed sensor is in the speedo head, so if the speedometer doesn't move it probably means the sensor is not sending out a pulse. The transmission relies on this signal.
#34
wow ok, thank you for info! Would i go about just changing the whole speed head or replace the sensor back there on mine?
#35
#36
The sensor itself can be replaced but very unlikely it failed. You need to determine if the cable is rotating.
#37
#38
Make sure you check the cluster to see that the mechanism moves freely. These cables don't normally break.
#39
When spun from back if cluster it moves freely an tach jumps a bit ..from engine bay at upper cable it does not spin which leave me to believe that upper portion is no good? Still having a very tough time finding this part
#40
This part is discontinued don't order new from any site that claims to have it, they don't.
bawlexus91
35
11-22-08 09:48 PM
