Hey all... My 96 ES has 195k miles on it. I am replacing my steering rack bushings this weekend, as they are shot!!
I would like to know what other bushings I should look at replacing while I am at it, since I am sure they are the original bushings since the car was born. Any advice on this would be appreciated. Thanks in advance!
I changed the stabilizer links, because old ones were shot, it made a huge difference, in the front end. It tightend everything up again. They are not that expensive
end links front/back [around 60$ for all four from rockauto]
Sway bar bushings, around 15$ for front/back
Thanks so much. I will do that. Hopefully it will tighten everything up. I do appreciate it. Happy Thanksgiving.
for sure the sway bar links... they are cheap and changing them made a huge difference to my steering. nice and tight with good resistance when turning....
when i took the old ones out there were totally shot...coud move the link with a thumb!
Same with mine, even when i go over man hole covers feels like it doesnt bottom out, if you replace the struts, springs, links, be even better.
Thanks everyone. I am going to replace it all! We shall see how this all turns out. Thanks again.
